1 - 9 of 9 Posts
I have to do both front wheel bearings. Everything I'm seeing online the bearing and hub are separate, no big deal.
But everyone say w/o abs.
I can't find a single one that says with abs.
Even when I looked at some parts stores they all say w/o abs.
Am I missing something here?
Sent from my XT1650 using Tapatalk
03 H6 OBW & 06 WRX Sportwagon
does a 99 have a tone ring on the axle and separate sensor?
maybe I don't understand but, rhouseman, idosubaru is a pro mechanic, he can guide you.
The hubs are not normal wheel bearing replacement parts. They are in some arena's of mechanics, but that philosophy doesn't gain anything here as Subaru hubs last the life of the vehicle.
Buy a wheel bearing kit and a hub, it ends up being two purchases instead of one, no big deal. Personally I would keep the hubs or get Subaru OEM hubs.
https://www.amazon.com/Genuine-Subaru-Bearing-Forester-Outback/dp/B01GID0FQQ
I wouldn't trust a replacement aftermarket hubs and studs to be better than OEM original. Not necessarily because aftermarket hubs are known to be poor quality, data is anecdotal since it's so rarely done and the top subaru specialists in the country have little to say about it. But rather - OEMs have significant long term trending data showing they don't fail and last the life of the vehicle so there's little reason to replace them outside of causative incidents like previous improper work, accidents, a catastrophic bearing incident etc, in which case a hub is bought to replace the one that was damaged by other issues.
That is confusing that FWD packages are offered. My WAG is that FWD Subarus are so rare, they're probably archaic listings from a bygone era of 1970's auto and trailer mechanics and maintenance and confusion companies had over the convoluted 1990-1995 EA to EJ transition (not to mention the schizophrenic MPFI changes just prior to that) just prior to the transition to online listings. Companies have never had financial incentives or reasons to clarify much since then.
A 1999 Outback doesn't have those issues - but does share a platform with some earlier vehicles and cross listed parts that do. For example - your 1999 Outback has the same front wheel bearings and outer wheel bearing seal as my 1989 XT6 which is from an entirely different planet.
https://blog.caranddriver.com/wp-content/uploads/2011/05/Subaru-XT6.jpg
No it doesn't. But the hubs are one way interchangeable - you can install 99 hubs in 2000-2004 but not the other way around. AFtermarkets probably just make "99 style" hubs and sell them for 2000-2004's.
never been paid for a job (well once over 15 years ago), never trained, or worked at a shop so "pro" is a stretch but a very kind one.
1 - 9 of 9 Posts
