2004 Subaru OBW L.L. Bean H6. 2003 Subaru OBW L.L. Bean Former 2001 Subaru OBW VDC owner.
Well if you didn’t know this, cause I didn’t , you absoluteLLy can remove wheel studs from the front and rear of your 2nd gen outback without taking off the spindle. I recommend buying 5 studs at a time, and use a little WD40 in getting them back in, it makes a world of difference vs not lubricating. I set out to repair one today, and ended up doing 4. Shame on the Ahole who carelessly boogered up those threads so bad that I had that many snap on me on alone one spindle.
I wanted to put this on the what did you do with your outback today thread, but I’m on my phone and could not locate the thread.
Good day subaru family.
Good pointer, thanks! Curious - what did it take to convince the old studs to pop out, just a little hammering?
I believe I could have hammered them out with no other help, but I used a map gas torch, little home depot deal, to heat up the first one, and it it came out just fine. The rest came out just fine, and I didn't even use the torch. The heat probably helped with the whole spindle being warmed up. Used a petty heavy steel hammer. I don't think you regular carpenters hammer would be enough. WD40 is a must when you install the new ones. I was able to fish the new ones in through the back pretty easy once finding the sweet spot.
