Will mitsubishi outlander wheels interchange with my outback. Both are 2003 with 16 in
2020 Outback Premier 2.5i
Here's where I'd look to compare any configuration. It also lists engine options and US vs foreign markets, which sometimes makes a difference. It looks like they'd fit but you'd need spacers and the offset is slightly less, which will move the tire curbside slightly.
Scratch that. I missed the fact that the bolt circles are not the same.
You'll want to note the year model of wheels that you want to swap, also the trims. certain performance/sport wheels might have different lug pattern to base trims.
Be very careful if you find same lug pattern wheels, you also need to match the center bore. As long as you go to a larger center bore size it will fit. Depending on how big the difference is you may want to have concentric ring spacers aswell.
The link provided by user Micron is what I use to determine fits too. It's a good resource.
