At some point the brakes changed around 00-02...when was the change?
And what was it?
I have 02 and 03 H6 OB's and would like to know....
another issue is the 02 had the door replaced so i don't have the original door plate to check the manufacturer date on it.
2004 Outback Wagon, Mystic Blue Pearl
Mid 2001. So you should be good.
Is 2001 manufacture date or model year?
Only definitive date i saw was "09/01" which suggests a manufacture date - implies 2002 model year and my vehicle....?
Guess i'll just pull apart and check...
My understanding is that the change occurred mid model year on the 2001 MY, so a 2002 MY car should be the larger rotors/pads.
okay great, thanks. i'll see what i run into with my 02 and 03 when i dig into this tomorrow and try to post back.
i'll dig into it and try to follow through with some information since i have an 02 and 03.
13 E350
my 02 with 2 cup center console and other revision options still came with 00 brakes, find out the hard way. Just take pads with you to the store and compare.
