1 - 9 of 9 Posts
2015 3.6 Limited, 2006 Forester, 2004 OBW 2.5 (sold) . .
My 4-banger, 5spd, 04' Outback now has 9,000 miles on it and I have been running Mobil 5w-30 Dino oil in it.
I did a nice gentle and extended break-in period with several oil changes already. I assume the rings are well seated and the engine is plently broken-in.
My question is WHEN is it safe to start running synthetic oil in it?
Thanks!
SubaruOutback.org Founder
2021 Outback Limited 2.5L - 馃崷The Ice Cream Man馃崷
10,000 is an ideal time to start using synthetic oil ;) Your seals are seated fine and your engine is broken in fairly well, have no worries. I recommend using Mobil 1 with a Mobil 1 filter as I've had good results with them so far :)
Superb Moderator, ,
MY12 WRX, MY07 FXT
Yes, it is absolutely safe for your switch to synthetic now. And I also recommend/use Mobil 1. And if/when you make the switch, use a good filter (Subaru preferably) and you can go 5k between oil changes easily. Brian
Oil
I think Castrol does have a pure synthetic. It is like 0w-30 and it says Made in Germany on the back.
Just a heads up.
I am currently using Amsoil in my 2002 Ranger and I am running it 10,000 miles and then getting an oil change. I will let everyone know how it looks. I have not check it in the last 8,000 miles. :D
I'm thinking of increasing my syn change interval to ~ 5,000 miles and doing the filter @ 2,500. I have in the past been doing BOTH @3,000! Getting expensive . . . . .
Now I use Mobil 1 religiously and change both oil and filter every 5,000 miles. Works out great every time ;)
18 horizontally opposed cylinders of fury
I think that *only* bottles of Castrol marked 'made in Germany' are true synthetic, you're correct that most Castrol you find is not.
I almost forgot- I did my first ever oil change a month ago, using a factory filter & Mobil 1. Everything is fine, there is no piston slap or any such noise. Its probably a coincidence, but I've gotten better gas mileage lately, too.
1 - 9 of 9 Posts
