Maybe this is a dumb question, but it doesn't seem readily apparent to me where I can remove the SD card for the Nav prog in my 2013 Outback. When I hit eject, where is it ejecting to? any special tricks to getting the card out?
Thx
Thx
Ejecting the SD card means the system is "unmounting" the card.. Once the card is ejected all you have to do is pop the little blue transparent protector above the volume control and remove the card.. Once you put the SD card back in.. the system will reconnect and mount the SD card again..Maybe this is a dumb question, but it doesn't seem readily apparent to me where I can remove the SD card for the Nav prog in my 2013 Outback. When I hit eject, where is it ejecting to? any special tricks to getting the card out?
Thx
One more thing, once you have the blue cover off then press on the card and it will pop out.Ejecting the SD card means the system is "unmounting" the card.. Once the card is ejected all you have to do is pop the little blue transparent protector above the volume control and remove the card.. Once you put the SD card back in.. the system will reconnect and mount the SD card again..
Hope this helps.. FYI..!! Also please review the owners manual (Nav Manual) for specific instructions on how to manage the data on the card.. I believe there are requirements to follow regarding adding/deleting data and formatting.. Be very careful.. you could corrupt the SD card..
Steve
