If you have a 2.5 (you don't say) there is no dipstick, this is explained in your owner's manual.
Someone here may have the procedure from the service manual, I recall it involves a specific fluid temp and maybe some gyrations of the shifter through the gears but I'm not entirely certain. Oh yeah - you need to crawl under the vehicle.
Considering the recent revelations of an extended warranty on the CVT (to 10 years/100K or 1 year from July 31, 2017), just take it to the dealer with specific info to reproduce the issue, they'll do a free inspection/assessment to determine if you qualify for a free replacement.
If your engine is the 2.5, hallux has the answer spot on.
In case you are unaware, Subaru has recently sent out letters to all owners of certain Subarus with a CVT. Yours would be included. The letter explains that Subaru is giving all owners an extended warranty on the CVT. How long the warrany is, depends upon how many miles is on your Outback. But almost everyone gets some coverage.
So do what hallux advises, and take it to a dealer. Let them check it out. If it's bad, you'll be getting a new CVT at no cost to you.
Also, unless you are seeing drippings or a puddle in your garage or driveway, it is very unlikely your CVT is low on fluid. That is why Subaru makes it a sealed unit. The only time it should be necessary to put new fluid in, is when old fluid has been taken out.
Good luck. It would be nice to hear back what the results are of your dealership checkup, if you decide to follow through with it.
P.S. I've driven through your town a few times, when I used to live in Madisonville, KY. I sure miss it some times.
