1 - 10 of 10 Posts
19 Limited/20 Onyx (7TH)
2008 outback 60K and just thought I d do all 4 pads and rotors as I do have a slight pulsing during high speed braking. My question is where to get best pricing. Would like OEM stuff or similar. Dealer wants $85 front pads, 85 rear pads, 85 front rotors, 85 rear rotors. Does that sound fair? Subaru online is almost the same plus shipping. NAPA? Suggestions. Thank you.
have you inspected them? often the rears will last thru 2 front pad swaps - might depend on a lot of factors.
with admittedly small amount of personal experience, I think Centric gives you good value. Rotors are decent quality and PosiQuiet Ceramic pads are on par with OEM and much less expensive. I run those pads on my wife's outback. I'm definitely using them again. I have bought pads for my Subarus from RockAuto and from KNS Brakes. In the past, I've bought from local parts stores for other cars.
You might try a bedding-in procedure to see if it clears up the unevenness of your rotors. Being in the NE, you may need to be diligent about inspecting for corrosion and lubing sliding/moving parts. Permatex Ceramic brake lube was recommended to me and seems quite good.
read here; -Warped- Brake Disc and Other Myths
Bed-In Theory
01 obw 2.5 5 speed
i like this place cause it's oem and they give you not only shims but the hardware clips that go on the calipers as well... looking them up your front's $69, rears $72, and about $72 for the disc... it usually takes two days for shipping. if i order monday night, would get them wednesday ,thursday the latest... but it might be different since i am in nyc...http://subarupartsforyou.com... hope that helps
$451 with shipping, sounds like alot, No? I did an online order but didn t submit, looks like no tax. FYI/ The dics are sold as singles.
BTW/dealer quoted $660 for the entire job.
if you ask for the cheapest ; hoses, belts, pads, plugs, etc. - almost any common 'consumable' on a car, you will get crap.
Thanks all, I went with Amazon, Raybestos pads/rotors, professional grade on all. Free shipping, $250 w/tax.
01 obw 2.5 5 speed
i normally buy just pads from them cause it includes the shims and other assorted hardware... the discs i get resurfaced...or buy from other online stores...
1 - 10 of 10 Posts
