I think I know, but I am looking for a few people to help me confirm, generally, what white chalk letters and numbers typically mean on car parts. And perhaps, specifically in this case. See attached photos. Thanks!
490479
490480
I still see them on my 13-year old 2008 OB, and it appears on original parts, so it was likely put on on the assembly line. I presume it's an inspection mark of sorts.
And it's not chalk, it's definitely a more permanent marker.
'19 Outback Touring 3.6R
Yes, this. And it's not just a Subaru thing!
It's when someone goes through the defective parts bin and marks them good to use (just kidding).
2017 Outback Premium 2nd Subaru owned
Quality control, inspection marks or inventory control. Sometimes it is to flag a part that needs attention prior to installation. If it is on the car and working, I would not be concerned. In earlier years on the assembly lines, marks were made all over the vehicles. With robotics and improved assembly methods it is not seen as much.
2017 2.5i Outback Limited w/ Eyesight, Wilderness Green
Those letters/numbers are definitely inspection marks, as others have noted. It looks like your photos have initials DT and KM(?) - likely the initials of the assembler or inspector who verified them. The numbers are less clear, but could be something like the employees clock/ID number, station number, date code (such as Julian date), etc. The manufacturing plant I work at uses check sheets where each employee signs his/her clock number to verify the assembly is complete before moving to the next station.
