2008 Outback with 2.5, non-turbo, 114K mi, AT.
The issue seems to be that the car does not know when to shift down to 1st gear at stop signs. If I stop completely (like you're supposed to), and take off, it starts in 1st and I can accelerate at any pace I wish. If I do a rolling stop (like you do when you're in a hurry), slowing to 1-2 mph and then accelerate, it seems to stay in 2nd, and it's fine. If I'm in traffic at a stop light, and have to slow way down to a crawl, it doesn't matter if I never stop completely or if I do, it starts out in 1st and does fine too. However, if a make a quick stop (may stop for only a fraction of a second), and then go, it stays in second until I accelerate, then it drops to first, and shifts a bit hard doing it. No other shifting issues between any other gears either. I've heard there is a tranny reflash that can be done at the dealership for under $100. Is this the kind of issue that the reflash can address? I have done the battery disconnect reset trick, and that doesn't seem to have helped.
