1 - 7 of 7 Posts
2020 OB Convenience, 2006 OB 2.5 MT
Hi, I just got a used 2008 OB with 17 inch stock mags and we get lots of salt and snow in Quebec so I wanted to know if anyone has put WRX wheels on with snows? I'm getting rid of my old Subaru but thought maybe I should keep the rims for winters. Has anyone put 2002 WRX 16 inch rims on an 06 - 09 Outback using minus sizing? I know the rim is narrower but often that is suggested for winter driving. My OB currently has 225/55R17 and I was thinking to put the 16 inch WRX rims on with 215/65R16's The tire size is a tiny bit larger over all so the speed variance is .96% too slow according to 1010 tires calculator.
In a week or two I'll try putting the rims on the car for clearance but until then Any thoughts from those who have similar experience would be helpful.
Thanks!
2008 Outback 2.5i
I believe so, but I a running General Grabbers instead of dedicated winter tires. We have to many mirical 70degree days to run true winter tires.
2015 Subaru Outback Premium | 2007 Outback 2.5i
Thanks!
I had stock rims w/215/65/16 Grabbers on my 02 OBS and have been wondering if I could but that exact set up my 07 Outback - I'm glad I came across this thread. Thank you.
So it looks like I will be looking to trade/sell my 225/55/17 set up pretty soon.
08 OB
have had my 16 in 02 WRX wheels on my 08 OB since I got it
works fine. I run 215/65-16 because that is actually closer to the 225/50-17 RE 92A OEM size than the 225/60-16
Ah good to know. As it turns out, I will have to stick with my 17in rims since I am putting LGT brakes all around. Once I add a lift, I should be able to squeak out a larger tire - we'll see, still more research to do.
Thanks for the follow up.
1 - 7 of 7 Posts
