My '05 Outback had a minor fender bender which required changing the left front fender and since the windshield was already cracked I decided to replace it at same time. Now that the car is back on the road it has a wind noise that was never there before, it starts at 25 mph and increases with speed. It seems to be coming from dash/firewall area. I have this rubberized foam piece left over after doing the repairs and wondering if goes somewhere below windshield or under fender to block airflow or something? Does anyone know where this piece might be supposed to be placed ???? 😳 It's about 16" long.
There's a piece of foam between the fender and the front door post that might have the same shape. It can be seen by opening the door and looking forward toward the front wheel. It might be missing. (Compare your driver and passenger side).
06 2.5 XT outback. What in the world was Subaru thinking by not having ALL the interior lights on when you open the doors?? I mean you open the door and the light in the center of the car comes on but you cant see squat up front unless you manually turn on one of the overhead lights. I have an...
There's a thread for the other three generations, so why not for us 3rd Gen Owners? Maybe somebody can sticky this?
I'll start:
I replaced the cheap summer blades that came on my 2008 with Rain-X Latitudes. I've used Bosch's in the past and though they work great I wasn't impressed with...
I cant find where the regulator is located, I'm getting random intermittent misfires , fuel pressure reads 46psi according to the dealership it's supposed to be 30-34 psi, and 41-47 with regulator vacuum off, I just cant find it to pull vacuum off to see what it reads with it off,
Greetings,
I have a 2007 Subaru Outback Basic. Was given a set of leather seats from a 2006 Outback XT. Kindly the previous owner clipped the wires and left the connectors. All the airbag connectors are there but it appears the wiring is not present in mine for seat power. Anyway, attached...
I have a new to me 2007 with the basic heat/AC setup. It is NOT duel zone. Car has plenty of coolant, warms up fine, and when it is warmed up the heater core has hot coolant flowing into and out of it. The blower is working fine but nothing but cold air flows out. I strongly suspect the...
