My 2006 Outback has a leak near the washer reservoir. It will entirely drain in a short time and the fluid
can be seen on the ground below the reservoir. I am having a VERY difficult time getting access to determine the
source of the leak. The reservoir is very low and it really doesnt help to remove the battery. To see the area the
plastic boot which is part of the wheel well needs to be removed. Even after this is done the side with the hose connections are
located on the non visible side. Is there a way to remove the reservoir entirely to connect new hoses? Other models
have the reservoir mounted higher. Thanks!!
