I'm starting to think that there is a design problem with the rear wiper. I've tried three now (Subaru, Bosch, Trico beam) and they all have the same problem. The ends contact the window, but the center where the wiper mounts to the arm does not.
Maybe? Not sure how to check or adjust that.Could it be spring tension on the arm itself that's the problem?
Me neither but I suppose I could put a kitchen scale under the arm to gauge the pressure? After trying three different blades and all of them have the same problem, the arm and glass are the only constants, and we can't change the glass.Maybe? Not sure how to check or adjust that.
I was thinking of the spring in the blade itself not the arm!Well, from a semi educated prospective - pressure on the glass should be a function of spring tension, yes? The spring is metal. Metal expands when hot, shrinks when cold, if my liberal arts education serves me well (???) If the spring has shrunk/contracted with cold, that should create more pressure....
It might be possible to piggyback a second spring or install a slightly stronger spring.You might have a point, but I’m convinced the arm is at fault. There is virtually no “snap” when I return it to the operating position. I should try holding finger pressure on the arm while it is in continuous mode.
Yep exactly that.A rear window center smear is by far my biggest pet peeve with an otherwise excellent winter driver (audio quality issues notwithstanding!)
