Hi all,
I have a 2002 outback 2.5 four cylinder. I replaced the head gaskets, timing belt and water pump this weekend. Everything has gone fine except I have one wire that I don't remember were it connects. :-( (I should have taken more pictures, but messed this one up.)
The wire comes out of the wiring harness close to the starter motor. It is a fairly large gauge black with with a yellow stripe. It is not the long similar wire that connects to the top bolt on the starter motor/bell housing. It is much shorter about 6 or so inches from where it comes out of the wiring harness.
In the terrible picture attached it is wire number 1, wire number 2 is the black with a yellow strip connected to the top starter bolt.
Can any of you tell me where it connects to?
Thanks.
John Harvey
Thanks.
John Harvey
