1 - 20 of 31 Posts
2002 OBW 2.5L 5MT
Hi,
Can anyone know if the WRX aluminium pedal set be able to fit on a 02 Outback 5MT? I saw a tread on Subhuman's writeup a few years back where he put the WRX pedals on his 04 LGT and they look great!!:29:
Jim
2002 OBW 2.5L 5MT
Discussion Starter · #2 ·
Any input will be helpful. I like the aluminium look of them.
2002 OBW 2.5L 5MT
Well, I have a set ordered last night via Subaruparts.com
$55.37 plus shipping. Can't wait to get them as my original rubber pedals are kind of worn out on one side. :(
Will post pics of the new do once I get them in.:29:
Jim
2002 OBW 2.5L 5MT
Got my pedals in today from the dealer. Can't wait to put them in this weekend. Here's a picture of how they look like all wrap in blue plastic sticky wrap. They are actually made in Japan....:D
01 Subie Outback-base
Can't wait for the pics....
2002 OBW 2.5L 5MT
Here they are....:D
I am thinking of Subtle's dead pedal plate next:29:
2003 OBW 2.5L 4EAT
Looks Great! How are they attached to the pedals? Do you know if there are WRX pedals like this for an AT? My gas pedal is the same, but the brake pedal on the AT is alot wider.
2002 OBW 2.5L 5MT
They are very simple. I just peel out the old rubber ones on the brake and clutch pedals (mine are bald on one side of the rubber from years of pressing against them) and slide the new ones on. The gas pedal, you would need to take the bolts out at the back (two bolts) and unloosen the back plate. You then unhook the spring and push the pin out of the plastic pedal. I use a small hammer and a piece of wood to knock the pin out. Once you get the pin off, just put the spring back on with the new pedal and push the pin back in. That's it....:29:
Not sure about the auto version but I assume it is base on the same principle.
2003 OBW 2.5L 4EAT
Ok Thanks! I found that part# 36023KE000 is for the AT brake pedal and part# 36024FA001 is the acceleration pedal and is the same as in the MT.
2002 OBW 2.5L 5MT
Discussion Starter · #11 ·
cool...yeah all the part# are in my first picture if you 5MT subies would like to do this mod:29::D
2002 OBW 2.5L 5MT
Discussion Starter · #12 ·
Subtle Dead Pedal
Ladies and Gentlemen....Subtle Dead Pedal with the WRX Aluminium Pedals:D
2013 Outback Premium 2.5 CVT
Performance suby,
Would you mind measuring the dimensions on those pedals for me? I'm trying to figure out if they would fit on my Gen4 Outback (AT). They look great on your car!
Thanks!
2003 OBW 2.5L 4EAT
If your planning to install WRX pedals in your 2013 Outback, you may need later version WRX pedals, especially since the acceleration pedal on the newer generations are one piece electronic units. Meaning that just the pedal cannot be changed.
The brake pedal should be the same or similar to mine though.
Here are the measurements for the brake pedal on mine:
1 - 20 of 31 Posts
