I have a 2018 Outback, and earlier this week the Check Engine (yellow-steady), Cruise control and X-mode lights (yellow-blinking) came on.
The gas cap was loose and I tightened it 2 days ago, but lights are still on. I have been putting the E-88 gasoline in the car the last few weeks, and I'm wondering if that might be the problem, or if there's something else going on.
Meh.
I has wagons.
What are the codes?
Super Moderator
Outback 2011 3.6R Premium
Codes normally only “reset” after several “normal drive cycles” (which usually involve around a 20 to 40 minute run without setting another code).
From memory you need to do four or five “normal drive cycles” before the codes reset.
Of course you can also reset with a diagnostic/service scanner and sometimes by removing the battery lead for around 30 minutes.
Seagrass
