2006 OBW - Airbag Light On - My fix
224K views 236 replies 134 participants last post by  nautika96
I have a 2006 Outback 2.5i Ltd, and the airbag light has come on since it has been cold out. On warmer days, the light will randomly display. So, I had the dealer run a diag on it, since my car was in there for a transmission issue. When I picked up my car, the dealer told me the light wasn't throwing any type of code, and they found the issue to be a burned out LED bulb, located in the map light overhead console. This is the passenger ON/OFF light, and sure enough, if I tapped on it, the light would flicker. I asked how much it would cost to fix, he said it would be around $340 (- the $65 i paid for the diag), and the whole overhead console would need to be replaced. SO for a burned out bulb, it would cost me $270...are you kidding me??!! I now understand why so many refer to the dealer as the STEALER. Unbelievable. I was told that since the airbag light was on, the airbags would not deploy.
So, I jumped online, and found the overhead console (OEM) sold for around $115. I looked at mine, and figured out how to remove it .... remove the lens, and 2 screws secure it. So, now I am looking at the cost of the part, installing myself, and saving the ridiculous $160 installation fee (I guess it is $80/screw).
I figured since I had mine out, I might as well look at it. I removed the PCB that contained the 4 LEDs. With closer inspection, I could see one of the components on the board was loose...as in there wasn't enough solder to secure it. So, I whipped out the old soldering iron, and bolstered it a little. I may have added a little too much, but it was the best I could do w/ the tools I have @ home (better lab tools @ work). Anyway, tested it....works perfectly. In the pic below, I have called out the component that was loose.
I'd like to know what you all think about it. If it's a legit fix, hopefully I help someone else.
Nice job.
So a single badly soldered surface mount resistor.
I like it when people use their common sense and intuition to arrive at a simple fix.
Nice work. I did the exact same think on my 2007 Outback. Was going to post the fix here soon. You beat me to it! LOL.
My dealership (actually both of the local dealerships) read the error code, 26 I believe, "passenger side indicator light malfunction", and told me that I needed to replace an ECU that is located behind the glove box console in the middle of the dash. $250 for the ECU and $100 to install. I'm glad I didn't listen to them. That would NOT have fixed the issue, $350 later.
In my case, once I had the IC board in my hand, I could wiggle the LEDs just a tiny bit and see that the solder on them was the issue. I just re-soldered the LEDs (and resistors, as well, just b/c I was already in there) and the airbag light has been off ever since.
Ok, here goes....
[instructions, with pic reference name in parenthesis] (since i cannot put pics in-line with the instructions)
1. Locate the two slots to release the map light lens (see MapLightConsole, LensSlot). Insert a small flat-blade screwdriver, and gently pry the lens free (see LensFree), and remove lens
2. With the lens removed, locate two screws, and remove (see LensRemoved)
3. Locate the two retaining clips, which need to be pulled slightly toward the screw hole to free (see RetainingClip). Once the retaining clips have been freed, the console can be dropped down.
4. Release three connectors (see ConsoleWiring, and LEDCableConnector)
5. On the under-side of the console, locate two screws, and remove the LED cover (see LEDCover)
6. With the cover removed, you will see the LED PCB. Remove two screws to free the PCB (see LEDpcb).
[Just looking at this pic, I realized I forgot to put the protective black foam tape back over the IC components, protecting them from the cabling]
Hope this helps out. If anyone wants me to PDF-it, let me know.
#107 ·
thank You!
my dash RED Airbag light was intermittent, and also my map light console was not displaying Passenger Airbag OFF, nor ON, also intermittent.
example of my dash RED airbag light ON:
I removed the map light console circuit board, and under magnification found 2 cracked joints
resoldered with a bit of extra solder on the fat tinned tip (not too easily in small space), so not showing you the poor quality of my work
reassembled and now Passenger Airbag On and Off lights work on map light console:
and now RED airbag light on dash turns OFF..
wooohoo!
Im cancelling the date with my mechanic
Pics and excellent step by step in Post 6 by @deccher
how to remove the map light console:
Like Totally Man!
Thank You!
this sounds similar to my problem...
I just bought an '05 Outback 2.5XT ltd.
My airbag light comes on, more often when its cold, and the passanger seatbelt light illuminates/flashes on the overhead console (where the map lights/sunroof switch are). The chiming noise is awful. It acts as if the seat belts are not being worn.
Did anyone have the seatbelt chiming when the airbag light was on?
hey lude,
no chiming here, but i can imagine the pain in that one (would drive me nuts).
while researching my airbag issue, i remember reading something about the airbag connector under the passenger's seat. perhaps it is tied to your issue, even though there is no mention of the chime. here is the post i found under another forum (suby forester). maybe it will help....
Air Bag light ON - Subaru Forester Owners Forum
dan
Thanks for the pics deccher, very helpful! I have an 07 OBWi, and have been staring at the red airbag light in the dash cluster, and the black hole in the overhead console where the "Off" light should be lit, on and off (most of the time) for about two years now. Finally read this thread and with the help of your pics reflowed a few solder joint on the small circuit board and now that is all good. Thanks again! (now if I can stop the CEL from coming on every 200-300 miles telling me I need new $1400 cats, I'll be good to go)
Thanks. I have this exact issue although I've not fixed yet. At least know I know what I need to do, and it's relatively easy.
To poster above, just get yourself a solder iron from ratshack and a roll of solder. May be helpful to practice on something first but up to you. Just be careful not to apply too much solder.
Yes! Wait at least 20 minutes before messing with explosive airbags or seat belt pretensioners. Most systems have electrolytic capacitors that store electricity, in the event that an accident destroys the battery or its connection on intial impact. The stored electricity can still fire the bags and pretensioners in the following rolls and hits that the car takes in the accident. After a while the charge leaks out to nothing and the items are safe to handle.
#21 ·
Well, I took the overhead console off and looked at the PCB and it all looks ok and nothing is loose...... I touched/wiggled all of the circuits and LEDs. Put it all back together and the ON/OFF lights come on when I start the car up.........then the OFF light stayed on...... No Abs light either..... WTH!?
I'll see how long it lasts.
#22 ·
It's possible that there is a cracked solder joint that was moved slightly when you touched/wiggled the circuits etc. Sometimes the cracks are not visible to naked eye -- I use 10X magnifier glasses and even then I've been fooled. If the symptoms show up again, I'd re-flow all the solder joints.
#26 ·
Great!
Based on the previous reports that should do it. But the OP was able to see the faulty soldering, whereas it wasn't apparent in your case. Because it was intermittent, I'd give it some time, enough that it probably would have hiccuped again before the solder was redone, and then call it fixed. Let us know.
#28 ·
Glad I found this article! I have had this issue for quite a while so I took my 09 Outback to the dealer today for him to run the diognosics. Came back with a code 26 saying a switch in this consoule. They wanted $495 to repair so I brought it home thinking there has to be a cheaper fix. I will be pulling this out and checking all solder joints. Thanks to all for the information provided. Dealer told me the air bag may not deploy when the light is lit, if this is the case why was there not a recall on this problem. It seams that quite a few people have had this issue for a number of years now. Talk about Subaru caring for you safety!
