2005 h6 engine timing
1 reading
8K views 3 replies 3 participants last post by  Luke R Johnson
Was replacing waterpump and while removing chains the time automatically slipped out if place. Note that the 05 H6 is different than The 2001-2004 h6. How do I reset the timing? I can find anything regarding the 2005 h6 online
Thanks I found this....
MECHANICAL(H6DO) > Timing Chain Assembly
INSTALLATION
NOTE:
•*Be careful that the foreign matter is not into or onto assembled component during installation.
•*Apply engine oil to the chain guide, chain tensioner lever and idler sprocket when installing.
1.*Preparation for chain tensioner installation
(1)*Insert the screw, spring pin and tension rod into tensioner body.
(2)*While depressing the tensioner onto rubber mat, twist it to shorten tension rod. Then insert the thin pin into the hole between tension rod and tension body to keep shortened.
NOTE:
Work on the rubber mat or other anti-skid materials.
2.*Using ST, align the “Top mark” on crank sprocket to 9 o’clock position as shown in the figure
ST****18252AA000
CRANKSHAFT SOCKET
3.*Using ST, align the key groove on exhaust cam sprocket to 12 o’clock position as shown in the figure
4.*Align the intake cam sprocket as shown in the figure.
(A)
Top mark
(B)
40°
(C)
15°
5.*Turn the crank sprocket clockwise, align the “Top mark” to 12 o’clock position (Piston #1 is in TDC position)
NOTE:
Do not rotate the crank shaft and cam sprocket until the timing chain installing was completed.
6.*Install the idler sprocket (lower).
Tightening torque:
69 N·m (7.0 kgf-m, 50.6 ft-lb)
7.*Install the timing chain (LH).
(1)*Align the timing mark (B) on the crank sprocket with mark (A) on the timing chain (LH).
(A)
Gold
(B)
Mark
(2)*Install the routing of timing chain (LH) on idler sprocket (lower), water pump, exhaust cam sprocket (LH) and intake cam sprocket (LH).
NOTE:
Check that the mark on timing chain (A) and cam sprocket (B) is aligned as same as aligned on crank sprocket.
(A)
Blue
(B)
Mark
(3)*Install the chain idler (upper).
Tightening torque:
(4)*Install the chain guide (LH: between cams).
Tightening torque:
6.4 N·m (0.65 kgf-m, 4.7 ft-lb)
NOTE:
Use a new installing bolt.
(5)*Install the chain guide (LH).
Tightening torque:
16 N·m (1.6 kgf-m, 12 ft-lb)
(6)*Install the chain tensioner lever (LH).
Tightening torque:
(7)*Install the chain tensioner (LH).
Tightening torque:
8.*Install the timing chain (RH).
(1)*Align the marks of timing chain LH and RH on the idler sprocket (lower).
(A)
Idler sprocket (lower)
(B)
Timing chain (RH)
(C)
Timing chain (LH)
(D)
Blue
(2)*Install the routing of timing chain (RH) on intake cam sprocket (RH), and then set the routing on exhaust cam sprocket.
NOTE:
(A)
Gold
(B)
Mark
(3)*Install the chain guide (RH).
(4)*Install the chain tensioner lever (RH).
Tightening torque:
(A)
Chain guide (RH)
(B)
Chain tensioner lever (RH)
(5)*Install the chain guide (RH: between cams).
Tightening torque:
NOTE:
(6)*Install the chain tensioner (RH).
Tightening torque:
(7)*Adjust the clearance between chain guide (RH) and chain guide (center) within 8.4 — 8.6 mm (0.331 — 0.339 in). Install the chain guide (center).
Tightening torque:
7.8 N·m (0.8 kgf-m, 5.8 ft-lb)
NOTE:
(8)*Check that each mark on the sprocket and timing chain is matched, and then draw out the stopper pin from chain tensioner.
