2010 2.5 COOLANT LEAK- water pipe o-ring?
1 reading
23K views 7 replies 5 participants last post by  dowquest
Has anyone replaced the oring/s(diagram part # G93301, SUBARU# 806933010) on this water pipe assembly? The picture shows the visible leak. Knock on wood I have not experienced any overheating, but I'd like to tackle this asap to avoid getting stranded. Is this a hard job to do?
Oh, I am planning to replace my serpentine belt, too. I had it replaced about 12k miles ago but now it's beginning to shred on the side. Ugh, an indie shop decided to put the cheapest brand or maybe old stock?! That one looks like an easy job. I should have done it myself then.
I appreciate any feedback.
I have not. That looks like a gasket though, not an o-ring?
At first glance it seems pretty straightforward to replace. Some general tips based on other cooling system work I've done in the past:
1. Clean mating surfaces thoroughly
2. Torque the bolts gradually to spec, alternating between tightening each of them until both are to spec (I can try to find it in the FSM if you need it)
3. Plan on topping off with Subaru Super Blue coolant and diligently work through the air bleeding to get rid of the air bubbles you introduce.
Yeah, at first I thought it's a gasket, but looking at the drawing it says o-ring- a $3.13 item.:frown2:And looking at the diagram, there's no flat gasket? Yes, if you can look up the recommended torque for the bolt that would be awesome. Oh, I completely forgotten about the coolant. Thanks for the reminder! I might as well do a drain/flush service the radiator with this job.
