Thought this might interest a few people. Was searching for something else and ran across it on the internets (publicly accessible).
NOTE: The Complimentary Upgrade period for subscribed STARLINK members ENDED on February 18, 2022. Subaru's current process is to replace any units that are not up to date (hardware replacement). This is done at the customer's expense, prior to a new enrollment in STARLINK services. The rest of the information around the complimentary upgrade period is left here for your information.
see attached Technical Service Bulletin 15-291-22 on procedures that are current POST complimentary upgrade period.
What Is Starlink?
Starlink is what Subaru brands their connected technology offerings. "STARLINK brings multimedia content, smartphone connectivity, seamless navigation, extra safety, and everyday convenience to Subaru vehicles. This suite of on-board technology helps make every drive more entertaining, confident, and enjoyable."
Since this is the 2016-2018 models, this upgrade is for the firmware/hardware that enables the Starlink Safety and Security / Security Plus feature set. What is that? According to Subaru:
"STARLINK Safety and Security helps keep you and your Subaru safe whether you’re in your vehicle, at your computer, or on your mobile device. Safety and Security services include Automatic Collision Notification, Enhanced Roadside Assistance, Stolen Vehicle Recovery, and the added convenience of Remote Services"
Go here to find out more - Starlink Safety and Security
What Is This Campaign?
Beginning in February of 2022, the wirless network provider for STARLINK Safety & Security, is retiring their 3G network. Things move on. Any devices that require the 3G network to function, including Starlink System1 devices, will need to be upgraded.
Summary:
Is This a Recall/Service Campaign?
No. "3G Network Retirement is occurring industry-wide and Subaru is providing a solution to support our active STARLINK subscribers who will be affected". There will be two Technical Service Bulletins issued just prior to the rollout of this update program (should be in the next two weeks). There are an estimated 193247 active subscribers eligible.
What Vehicles/Years are Affected?
Will I Get Notified?
If you have a current Starlink subscription, you will get an email notification. NO physical letters will be mailed out for this one (the notifications are sent by Subaru of America, and not Care Connect).
There are four notification periods as follows:
If you schedule service, and they look up any applicable Technical Service Bulletins (TSB), this should show up after the middle of March when the TSBs are released. I wouldn't count on that as a notification. Watch for an email and/or be proactive and schedule a service appointment.
Call your dealer and have them verify your VIN to see if you are affected/eligible.
Does it Cost Anything?
If you have a current (active) starlink subscription, and you have the update performed within the complimentary program time period, this is free to you. March 18, 2021-February 18, 2022.
After February 18, 2022 - there is no complimentary upgrade if you were not subscribed prior. If you wish to subscribe after that date, an upgrade to your DCM is required, you will have to pay for the DCM to be replaced before you are eligible to sign up for starlink services.
If you don't have an active subscription, the guidance in the documentation indicates a customer may sign up for starlink and then have the complimentary upgrade performed at no cost to you:
ANY Diagnostic Trouble Codes (DTCs) encountered during vehicle preparation are not covered under the complimentary upgrade. Those must be investigated/remediated prior to performing the upgrade. If your car has a warranty, they would be covered. If you don't have an active warranty, any work to troubleshoot and fix DTCs are billed as regular service items.
There is a backup battery that is NOT part of this upgrade service, and you might want that replaced depending on how old it is... that wouldn't be free (the backup battery is attached to the DCM module). You might get an upsell on paying to replace that little battery. Your choice. It isn't likely to be discounted because of this upgrade program, so maybe wait till it fails eventually.
Why Do I Need an Active Starlink Subscription to Get the Update?
Part of the verification process for the firmware upgrade is a functionality/usability test. The car has to have an active subscription to perform that test. This is tested in the vehicle preparation step (beginning) and after everything is complete (end). The guidance in the TSB explicitly states that this is a necessary condition to proceed with the upgrade.
Also, any vehicle that has had the upgrade would not be released until functionality has been verified, and you need an active subscription for that to occur.
What Gets Fixed?
Depends on what is needed. You will either get a NEW Data Communications Module (DCM) or a software update to the DCM. There will be a specific TSB released for each of the two solutions.
UPDATE FEB 21, 2022: the complimentary upgrade period is over, these TSBs are no longer in the system, and are not valid going forward. TSB 15-291-22 replaces both.
Why Does a Firmware Update Take So Long?
The firmware update is in 2 parts, each part has a disclaimer that it may take up to 60 minutes to complete. The amount of time allocated for a claims form for a firmware update that is successful is 1.9 hours. One that fails and has to have the physical DCM replaced is 2.3 hours.
The firmware update process is not a straightforward load one firmware and check version procedure. It's complex, and there are multiple modes of failure.
Each firmware flashwrite involves a cycle of checking the existing version, loading the proper file to write, performing the write process, moving the shifter from N to Park depending on the step - in neutral during the flashwrite, but the car has to be in park to power cycle the ignition, then has to be moved back to neutral for the next one, then cycling the ignition after waiting on prompts... lots of room for errors or problems.
Example - the on screen prompt for the Subaru Select Monitor says to have the vehicle in PARK, but for this one it MUST be in NEUTRAL. The TSB instructions are explicit on this at the beginning of those sections:
If all that takes a little longer than you think it should, but the process is being followed, not sure I'd complain about that.
The functionality testing section after a successful flashwrite should go quickly - if there are communication errors, then they just move the vehicle and press the iButton again.
What if I Don't Upgrade?
If you don't have an active subscription, nothing happens.
If you have an active subscription and ignore all the emails, your subscription will be canceled in February 2022 and any remaining time would be given back to you as a pro-rated refund.
If you wanted to sign up for STARLINK services after February 2022, you'd have to have your DCM replaced with a new one, at your cost. No complimentary upgrade - that was for subscribed STARLINK users to prevent interruption in service.
New guidance on replacement after February 18, 2022 is in this document (attached at bottom of post)
Online FAQs/Customer Care:
These will be available online at Subaru.com starting March 8, 2021. On MySubaru (desktop/app) beginning March 18, 2021.
The following groups should already have FAQ sheets/resources available if you contact them with basic questions or to schedule service: Customer Advocacy, STARLINK Customer Care, and Shift Digital (Service Concierge).
Currently, in this post is most of what they know... until people start getting replacements and common questions are answered and posted in updated FAQs by Subaru, you know what they know.
Other:
I attached a PDF output of a spreadsheet linked in the training material - give you an idea of how many active Starlink subscribers are potentially impacted at each retailer... maybe see how busy your retailer is likely to be with this.
Revision History:
Mar 11, 2021 - updated notification area (added locations where FAQs may be posted at some point). Corrected release dates per post #9.
Mar 18, 2021 - TSB numbers added , detail to some sections.
Mar 24, 2021 - TSB number/date updated. Clarification text on complimentary for active subscribers only.
Mar 25, 2021 - TSB number/date updated. 15-279-21 date changed from 3/18 yet no R prefix added.
Apr 01, 2021 - TSB number/date update. 4th revision on 15-280-21R (released April 01)
Apr 12, 2021 - TSB 15-280-21R (Mar 25, 2021 revision) is attached. WQZ-61R attached because the TSB references it.
May 20, 2021 -TSB 15-280-21R (Apr 13, 2021 revision) attached. Changes noted in text of post.
Aug 23, 2021 - added links and info to sign up or renew STARLINK subscription
Feb 28, 2022 - attached TSB 15-291-22 and updated information about DCM replacement post Feb 18 2022.
Feb 16, 2023 - 3G sunset complimentary upgrade is well past over. Top post no longer actively updated. Information won’t change going forward.
What Is Starlink?
Summary:
- Complimentary upgrade program ended on February 18, 2022 (see TSB 15-291-22 attached). No more free hardware upgrades.
- Complimentary upgrade program began on March 18, 2021 (was March 10)
- For active subscribers only. If you want a module upgraded and you don't have a subscription, you’ll have to enroll.
- Deadline is February 18, 2022. After that, any active subscribers that haven't upgraded will have their current subscription canceled.
- Email ONLY notifications to owners with an active STARLINK subscription will begin March 18, 2021 (was March 10)
- Active STARLINK subscribers get a free upgrade, either a new Data Communication Module, or a firmware upgrade.
- This is not a recall/service campaign, it's a solution to continue to support a provided service
- There is a possibility that, even with a software update, a later DCM hardware replacement may be needed (see post 192)
- Estimated 193247 active subscribers eligible for upgrade
• 2016-2018 Forester 2.5i Premium • 2016-2018 Forester 2.5i Limited • 2016-2018 Forester 2.5i Touring • 2016-2018 Forester 2.0XT Premium • 2016-2018 Forester 2.0XT Touring • 2016-2018 Legacy 2.5i Premium • 2016-2018 Legacy 2.5i Limited • 2016-2018 Legacy 3.6R Limited • 2017-2018 Legacy 2.5i Sport • 2016-2018 Outback 2.5i Premium • 2016-2018 Outback 2.5i Limited • 2016-2018 Outback 3.6R Limited • 2017-2018 Outback 2.5i Sport | • 2016-2018 Impreza 2.0i Limited • 2016 Impreza 2.0i Sport Premium with Eyesight • 2016 Impreza 2.0i Sport Limited • 2017-2018 Impreza 2.0i Premium • 2017-2018 Impreza 2.0i Sport • 2016-2017 Crosstrek 2.0i Premium with Eyesight • 2016-2018 Crosstrek 2.0i Limited • 2018 Crosstrek 2.0i Premium • 2017 WRX 2.0T Premium with Harman Kardon • 2017-2018 WRX 2.0T Limited • 2017-2018 WRX 2.5T STi |
- March 18, 2021: Customers with an active STARLINK subscription will be sent an email from Subaru of America, Inc. - this email content “Call to Action” will have a link to schedule service with your preferred retailer in MySubaru (if you have one listed) otherwise it will guide you to a "Find a Retailer" option. (was March 10 - see explanation in post #9)
- August 2021: Reminder email
- January 2022: Reminder email
- February 1, 2022: an automatic subscription cancellation email will be sent to all customers that still have an active subscription, but have not completed the complimentary system update
- Subaru.com - FAQs landing page will be available by March 8, 2021
- MySubaru - FAQs will be available by March 18, 2021 - App and Desktop
- Retailer Websites - Landing Page will be available for use with customer-facing FAQs; more details will be posted on Subarunet when the page is active that will detail any retailer-required action if applicable, the Digital Performance Consultants (DPCs) will also be alerted.
- "An active STARLINK Subscription is required prior to completing the complimentary update; if the customer is not an active subscriber and is interested in receiving the update/service, they have the option of enrolling in a STARLINK subscription first".
- "Claim will be submitted as a Policy Adjustment; An active STARLINK Subscription is required prior to completing the complimentary update; if the customeris not an active subscriber and is interested in receiving the update/service, they have the option of enrolling in a STARLINK subscription first"
- "If the Telematics LED is RED and Telematics a DTC(s) (other than B2A0E) is current: STOP THE UPGRADE PROCESS. The customer must be notified of this condition before any work begins. DTC repair is not included in the scope of work for this no-charge upgrade. The reprogramming service cannot be attempted until the Telematics system is DTC free and the Telematics LED is GREEN."
- "Unsubscribed vehicles are not included in this no-charge DCM reprogramming update. NEVER attempt this update on any unsubscribed vehicle."
- "If the subscription status is not "Active", the vehicle is NOT ELIGIBLE for the DCM update procedure."
- "NEVER release the vehicle back to the customer until the GREEN Telematics LED is illuminated and the Telematics System passes all functional and operational checks. The only exception to this requirement would be an external concern affecting DCM operation which the customer has been informed of but elects not to correct prior to receiving this update."
- "Any Technician or other retailer personnel who, despite service documentation and training to the contrary performs a DCM swap on a subscribed vehicle must NEVER release the vehicle back to the customer until proper operation of the Telematics system has been confirmed."
What Gets Fixed?
- TSB 15-280-21R Gen1 Telematics Reprogramming for 3G Sunset, released April 13, 2021 (5th revision).
- TSB 15-279-21R Gen1 Telematics DCM Replacement for 3G Sunset, released March 31, 2021 (2nd revision).
- There are two different firmwares for phase 1, depending on the version that is present on the existing DCM
- Improper identification of the existing firmware and applying the incorrect first one results in an unusable DCM and it will need to be replaced.
- Regardless of the firmware chosen (model/trim), the prompt to continue will show the model as "Forester" for all of them. Visual confirmation at this point is confusing.
- Not waiting long enough between pause prompts at the end of the write process (30 seconds) will cause it to fail (banner is not displayed for 30 seconds, technician must time this manually)
- Using something other than a Subaru approved Denso SSM4 data cable can intterupt the data transfer causing failure.
- Once the first firmware is successfully applied, a second one is applied. It can take just as long as the first one (up to 60 minutes).
- If either step fails, there are three scenarios for reapplying the firmwares, the proper one should be chosen. The guidance is to attempt the write procedure again a maximum of 3 times (implied original attempt, then 2 retries). Add more time for a retry attempt or two (up to 60 minutes per file, 2 extra attempts, either one or both files depending on condition)
- in addition, any retry attempts require a 5 minutes (or more) pause between attempts for the car to power down all the way (not specified what happens if you don't - assumed that the flashwrite will fail the next attempt).
- The vehicle must be in N during the flashwrite procedure to prevent the CAN from powering down, but moved to PARK in order to power cycle the ignition.
- The DCM is checked for basic functionality after the second firmware is successful - LED lights are GREEN and do not indicate a problem.
- A call is placed to the STARLINK call center using the iButton. The call center operator is asked to confirm the VIN and the location of the vehicle. This is done at the beginning of the process, and again after the firmware updates have been applied.
"Ensure the Midtronics GR8 / Midtronics DCA-8000 in Power Supply Mode is connected to the vehicle, the parking brake is engaged, ignition is in the “ON” position, the engine OFF, the shift selector in NEUTRAL and the wheels blocked. The reason this must be done is to ensure the power supplied to the DCM is not turned off. If this step is not performed, the CAN will power down the DCM during the reflash and the reflashing will fail resulting in irreparable damage to the DCM"
15-291-22 | Technical Service Bulletin | Gen1 Telematics DCM Replacement for continued operation post-3G Sunset | 02/18/22 |
Other:
Revision History:
