2020 Legacy Sport (2.5 with CVT) is trying to kill me
6.8K views 57 replies 16 participants last post by  jeff311omaha
#1 · (Edited)
About a year ago (I'm guessing) I had a bizarre issue when leaving a 4-way stop in a neighborhood. As I pressed down on the accelerator, the car seemed to simply idle/crawl into the intersection at what sounded like the lowest possible RPM for 1 or 2 full seconds. For the next 1-2 seconds, I started pumping the accelerator out of confusion wondering wtf was happening, never flooring it completely. Out of nowhere the engine bounced off of the rev limiter 5 or 6 times (still not even close to floored, still happens with any amount of pressure on the pedal - INCLUDING NO PRESSURE - once this process starts) and then came back down to "normal" and began to accelerate normally like nothing happened. No check engine light, no weirdness, no nothin'. I thought to myself, "Gee, if I was turning left at a busy intersection I'd be dead."
This has happened about once every month or two ever since and doesn't seem to have any rhyme or reason to it. It's never happened to me within a few blocks from home or work, so it doesn't appear to be a cold start thing or not. It doesn't seem to happen immediately after getting a new tank of gas either.
After the 2nd or 3rd time it happened I ended up talking to Subaru service at my dealership and they wanted me to make sure I didn't accidentally bump the shifter into manual or neutral mode (okay) and to keep an eye on things if it happened again.
Well, last week it DID happen again while I was turning left in front of traffic. Nothing yeehaw or anything, just a normal left turn. If the driver that swerved like a BOSS hadn't been paying attention I would have gotten absolutely demolished in a massive t-bone wreck that I would have 100% been at fault for. I immediately pulled into a parking lot and called my dealership and told them that they needed to look at it ASAP.
I was able to drop it off and get a loaner on Friday after detailing the symptoms. I did indicate numerous times that I hoped the symptoms immediately mean something to them since it would be nearly impossible to replicate by the tech.
FWIW, I am the original owner and opted for the most expensive available warranty after I bought my car after the lease was up. After clearly articulating what the problem was, they sent me on my way with a loaner. Friday afternoon they called me up and told me that there was an overfill 1.5 quarts of oil in my car which could be the problem or part of the problem. I JUST switched back to getting oil changed at "my mechanic" 4 or 5 months earlier, including an oil change that was done the previous week. They indicated that this could be part of the problem and could affect how the warranty work would be covered but also said that they didn't yet know what the issue was because they weren't able to replicate the issue. When I reminded them that they performed the oil change immediately before my initial call-in pertaining to this, they still said that they would need to perform a correct fresh oil change ($80 on me) so they could begin accurately diagnosing the issue.
I called my mechanic (who I would literally trust with my life) up to let him know what was going on and he immediately called BS. "They saw the oil change sticker and it didn't say Subaru. They're looking for a way out." He said that he'd be happy to get it back to "normal levels" free of charge if I grabbed it from Subaru and took it straight to his shop, also pointing out that there's no way there was an extra quart and a half in it when it left his shop, but there sure as hell would be now if Subaru was OK with me picking it up so he could correct the issue for free.
I asked the service writer at Subaru if I could just pick it back up so my mechanic could "correct his error" and they decided to simply take care of it on the house so they could continue diagnosing the main issue.
1) Does anyone have any idea what my initial problem could be? I was shocked that the symptoms weren't immediately an indicator of a known issue.
2) My mechanic literally has one of the best shops in town and he swears up and down that there's zero chance that he made a mistake on something as mundane as an oil change. Is this a tactic that anyone has ever heard of before or is it simply likely that he made a mistake and it has no bearing on my issue?
This is not a known issue on the forum but only a small minority of owners make their way here. I'd make an NHSTA report, and if they can't properly diagnose and fix the problem, get rid of the car.
I'd also call Subaru of America and express how alarmed you are at this issue and that the dealership is claiming that they can't reproduce this intermittent yet dangerous issue and ask them to help the dealership figure this out.
I presume you don't have a throttle controller or anything? I'd wonder if the throttle itself is having an issue where it's not consistently providing clean inputs to the ECU for the drive by wire system, so that the throttle body butterfly isn't responding, or some other electrical/electronic issue.
#5 ·
I don't have any aftermarket anything on my car. It's had all the recommended services and is relatively low mileage for being a four plus year old vehicle.
When I explained everything to my mechanic after Subaru said he did a bad job changing the oil, he immediately said it had to be something with a throttle position sensor or fuel system issue and nothing to do with the transmission like they had initially speculated. Obviously nobody knows what's going on yet but this is off to an extremely unfortunate start.
I was really hopeful that this was a known issue 😕
Sounds like a computer or sensor issue to me. Not an exact 1:1 but I had a similar issue with my motorcycle. Difference was it wouldn't drop back to idle when getting out of the throttle and would stall instead. Dealer flashed one of the computers and that resolved it. Hopefully your issue will be as easy to resolve.
I'm sorry to hear of this terrifying experience & hope it is resolved soon. While I haven't touched a Gen6 I know the accelerator pedal assembly on my Gen5 has redundant TPS's within it & if they ever aren't in sync reporting pedal application that would set some fault codes. Also, one of the options in my head unit under car info --> vehicle monitor is for accelerator valve opening rate, if there is something similar in yours that might be a data insight to how the car is reading your application of throttle?
There is a throttle relearn procedure that has helped a lot of the Turbo model owners resolve strange throttle issues with their vehicles. Maybe this is worth trying.
As a starting point If it was my vehicle, I would be cleaning the throttle body, removing the negative battery terminal for 10 minutes to reset the ECU and then do the throttle relearn.
If this does not fix the problem it was a low cost option and at least you then know these things are OK.
Seagrass
#11 ·
There's no chance there was extra oil in the car, regardless of the fact that a mechanic could hypothetically leave a wrench in your engine bay. This issue happened when Subaru was changing my oil when it was still under my lease. I understand the concept of double checking the mechanics work, but realistically that's not something I'm likely going to do when it comes to any skilled professional. I paid them because they know what they're doing.
My suggestion would be to begin logging data while driving. I have an odd, intermittent momentary hesitation on my '14 Mazda3 I've been trying to track down and have finally gotten a setup I'm somewhat happy with.
The OBD adapter is an older Etekcity Wifi version and the app is OBD Fusion. It's $10 but is worth the minimal investment. You can set up logging to be automatic upon connection or based on an event. There's a pretty big list of parameters you can add as well. It creates a file each 'trip' and you can email them out.
I'd be looking into all of the accelerator pedal positions, throttle position, and fueling.
#14 ·
The dealership still has the car. If they don't have a "We definitely fixed it" mindset and tell me "Welp, we corrected the oil issue, see if you die now," answer I will likely do something like that and put a camera in the car.
#15 ·
Happened to me multiple times, but it’s usually eyesight reduces power because it’s reacts to the Car currently passing in front of my car...
Problem is the car "far away" and no longer far away if I’m keep rolling into intersection instead of accelerating into it..
This is among the most scary car problems you can have and my parents did, indeed, once get rid of a car (Cutlass Cierra, terrible car) whose carburetor would inexplicably lead to fuel loss while turning left into traffic. Make noise with the dealer and Subaru. Tell them you can't drive the car the way it is. You may or may not get anywhere, but it could be the only way to make progress. Sell if it doesn't get anywhere. If you are up for some lengthy and (very careful!) real world testing you might be able to figure it out, but only some people have time in their life for that.
Some guesses:
Transmission control module or actuator (these have a clutch or clutches right?)
Throttle position sensor
Fuel pump or blockage
Here is a quick thing to try. The top most panel on your dash infotainment can be configured with three vehicle info readouts. Not many options. But one of them is throttle position. Put that up on the display and leave it there. I don't know if it's commanded or actual position, but if you push the gas pedal down and that % doesn't change, or it does change when it shouldn't, you have found something out.
#26 ·
Some guesses:
It's so sporadic that I don't see how I could test for it to be honest. I dropped it off with the hope that they immediately knew what the problem was based on my symptoms because I 100% knew for a fact that the tech wouldn't be able to replicate the issue. The moment they started blaming me getting my oil changed elsewhere I knew it was going to be a bumpy ride.
I didn't hear back from them yesterday, so I'm assuming that no new is not good news. We'll see. I have a loaner that they'll eventually want back! I have a 23 or 24 Crosstrek that has an oddly buttery smooth identical engine/transmission combo that seems faster and definitely gets better gas mileage than my lighter 2020 Legacy.
#27 ·
Just got the call back from the dealership.
While they were not able to replicate the initial issue, they are confident that "resolving the oil issue" will fix the "My car is trying to kill me" problem. The tech stated that it essentially felt like a different car once they did that. As someone who has driven that car for over 4 years I can say that it's been the same joyless vehicle to drive before and after this problem (let alone my most recent oil change), so I AM EXTREMELY EXCITED to see how my car has magically been rejuvenated by "resolving the oil issue" that they claim happened when I got my oil changed a couple weeks ago. They also did a transmission relearn, so that's fun.
Needles to say, I am dubious.
#28 ·
I can see how you would be dubious. It is true that overfilling can cause driveability problems, I think Subaru has put out some info on that even, but .. idk. Hopefully it does resolve your problem. Presumably your last oil change is somewhere in the recent past, and i think it was happening before?
If it hasn't been suggested yet, go Google a diagram of the various grounding locations in the engine bay - which is to say, all the places where the electrical system is connected to the unibody. Occasionally having one loose can cause very random and frustrating electrical problems. Is this likely, no, but a few minutes securing them all with a small wrench will at least rule it out for the future.
#29 ·
Subaru has put out a tech tips saying that overfilling can cause drivability issues, however the description of the problem that @jeff311omaha experienced intermittently but present over a span across multiple oil changes makes me think that unless the car was consistently overfilled then the problem didn't start with overfilled oil and it's not likely the root cause. The techtips article is attached as a PDF.
#32 ·
About a year ago (I'm guessing) I had a bizarre issue when leaving a 4-way stop in a neighborhood. As I pressed down on the accelerator, the car seemed to simply idle/crawl into the intersection at what sounded like the lowest possible RPM for 1 or 2 full seconds. For the next 1-2 seconds, I started pumping the accelerator out of confusion wondering wtf was happening, never flooring it completely. Out of nowhere the engine bounced off of the rev limiter 5 or 6 times (still not even close to floored, still happens with pedal completely depressed once this process starts) and then came back down to "normal" and began to accelerate normally like nothing happened. No check engine light, no weirdness, no nothin'. I thought to myself, "Gee, if I was turning left at a busy intersection I'd be dead."
My father-in-law experienced this problem and when I was riding with him I saw that he drove with left foot brake and right foot throttle. He has his left foot on the brake and pushing on the accelerator at the same time with his right foot. In getting ready to turn, he would step on the accellerator a bit more and then release the brake. As soon as he released the brake and started to turn the car stumbled and took awhile to get going again. I was able to duplicate this on my 2020 as well.
#35 ·
I'm assuming they were elbow deep into everything pertaining to the transmission for what it's worth. Honestly I can't speak to any of the specifics other than the very limited information that they gave me. They did have it for a few days where I just straight up didn't hear from them and I'm pretty sure they were aware that this had the potential to be a big problem so they had more than one set of eyes on it.
#36 ·
I had a similar problem with my 2013 Outback, soon after I bought it. The car has a CVT transmission.
The car would periodically -- and apparently randomly -- switch itself into its so-called "limp" mode. The engine continued to run but at very low RPM, as if the car was at idle. It did not respond at all to the accelerator. It would merely limp along at a crawl.
I discovered that pulling over, turning off the ignition, then immediately re-starting the car returned it to normal operation, until the next occurence. Shortly thereafter, I discovered that placing the transmission momentarily into Neutral also returned the car to normal operation.
This problem occurred as often as 4-5 times per day, but occasionally did not occur for a two or three weeks. The problem usually occurred at low speeds -- under 35 MPH. But on one unhappy occasion it happened on a busy two-lane highway at 65 MPH. Not fun.
The dealer never found a problem. The car never threw any codes, even when it went into limp mode only a few blocks from my dealer. The dealer tried to blame it on improper installation of my hand controls, but I've driven with the same type of hand controls for 50 years and knew it could not be the cause.
This annoyance persisted for nearly a year including two firmware updates by the dealer, then magically went away after a third firmware update. Subaru never acknowledged a problem with the car. I am still driving the car 11 years later, with the same set of hand controls, and the problem has never recurred.
- Jeff
#37 ·
if i recall, some cvt vehicles 2010-2012 had a similar issue where the torque converter was too locked up to accelerate , like starting out in 4th gear with a manual trans) ,and some stalling conditions. This was caused by a seal getting damaged and bypassing fluid. No external leaking. Just a possibility . If your problem is magically fixed, it was due to cvt programing and not oil change imho.
#38 ·
Man, you REALLY need to get rid of/stop driving that car. Yesterday. No one at Subaru, your insurance, or really any business cares about you as much as the people in your life. If you are killed/injured/maimed, there’s no replacing YOU or returning your body to complete health for the rest of your life.
Even crushing an ankle or breaking up a knee or shoulder will cause you pain and lower your wellbeing forever. Not to mention the medical costs/time from work and LIFE that Subaru will not cover fully.
No amount of lawsuit $ will replace any of that. You will be a statistic for damage control; car companies let a certain amount of deaths/injuries occur before they even address a problem. Remember the Toyotas (?) that would accelerate out of control with no way to stop them? A LOT of people had to be affected before they did anything. Bean counters/damage control don’t care about one case.
Instead of yourself, imagine that the person you love MOST in this world drives your car one day (even if it’s your dog like the Subaru commercials lol) and are killed/injured/maimed. We all take risks for ourselves at times, brush them off. But we usually don’t want our loved ones to take the same risks.
Please do not drive this car one more day. In fact, I don’t know at all, but perhaps speak to an attorney and get him to write all of this down so it’s recorded, and send them a letter about it. Recording that they knew about it a long time. And perhaps they need to give you enough $ to buy a replacement.
#44 ·
It happened again last Friday while attempting to pass someone, not while starting from a stop. Same exact behavior though (zero acceleration while pressing the accelerator for numerous seconds and then wildly hitting the rev limiter for a couple seconds out of nowhere, even if I'd gotten off the gas before the rev climb). It's been at the dealership since Friday and I haven't heard anything yet.
#45 ·
It's still there.
They had to call the mothership and await a response apparently. I've had a new Crosstrek for a loaner this whole time but I suuuuure would like my car back! They called 2 weeks ago stating that the QSM? (probably the wrong acronym on my part) said that the data indicated that there was too much carbon buildup in the motor. They sent me some borescope pictures and said they had the cleaning approved to do under warranty. They tried to say that that buildup could somehow cause this issue I've been having so randomly. I understand how that could make it sluggish, but I fail to see how it could allow the motor to spin up to redline with the CVT completely disengaged while still in DRIVE, as is the 2nd half of my symptoms.
My normal (very experienced and trusted) mechanic looked at the pictures and said it looked more like a 60k mile car, not a 45k mile car, but there's NOOO WAY it had anything to do with the issue I was having. He did say that it was a nice-to-have service done for free. We're convinced they are just searching blindly to find SOMETHING to fix to see if it helps.
That being said, I don't want to drive that car again until they have a Eureka moment and definitely say that they have done something that should resolve my issue.
I do have a customer advocacy person from Subaru who reached out to me 3 weeks after I initially emailed them, so SOA is at least aware of the issue. They did say that at this point "It may make more sense for me to take it to another service center," to which I said absolutely not.
Real fun.
