Driving on a full sized spare tyre
1 reading
5.7K views 5 replies 6 participants last post by  dukey33
Hi everyone,
I drive a 2016 Outback 2.5 L Petrol. I need new tyres. They came with Pirelli.
Any suggestions as to a good quality tyre? Also, has anyone bought from Buy Tyres Online At Cheap Prices | Car Tyres Online | Tyresales
I have been quoted $1295 for some Bridgestone from
Bob Jane.
Also...does anyone buy into the theory that driving on a new full size spare, with the other three tyres almost five years old, will cause damage to the precious AWD mechanics
( sorry to put it in layman’s terms).
I’m looking at driving 120 km to the Mornington peninsula and back. Then shopping around for tyres.
Many thanks
Bridgestone tyres are not worth the money you pay for them. Try Hankook Optimo or their Eco tyre if you do not do a lot of off-road driving. Alternately look for a Continental brand tyre.
Both of these should be much cheaper than Bridgestones and much better tyres too.
Driving 120 Km’s should not be a problem in my opinion.
Seagrass
Reactions: Currypeter
I wouldn’t like to drive my Outback ~240km with one new full size & three five year old tyres if they had a considerable difference in circumference.
I had Bridgestone Potenza RE001 Adrenalin tyres on one of my Foz XTs & I couldn’t wait to get rid of them. Never again.
I had Toyo Teo Plus tyres on my 2004 Outback 3.0R & also on one of my Foz XTs & I was happy with them. They suited my driving style.
I’m a fan of Michelins (the better ones) after having them on a Range Rover & a Discovery.
I had a loan Forester that had Cooper CS5 Grand Touring M&S tyres fitted & I liked how quiet & smooth riding they were. They also tracked & steered nicely but I don’t know how good a handling tyre they were.
Wow...$1295.00 for a set of tires...er...tyres. Not sure what that would be in Canadian $$$ but it sure seems steep to me. The most I’ve ever paid for a set of rubber is between $800.00 and $900.00. I usually get Michelin Defenders or primacy mxv4 for summer tires and Michelin xice snows . I always wait for a sale on them too.
as for using tires with different tread depth, they do say not to do it if there is any more than 3 or 4/32 difference in tread wear. I have not however, heard of any issues from doing it. i Have replaced two tires at once when one has gone flat and can’t be repaired just for that reason. I leave the spare in the well unless it’s needed...and check it’s pressure every six months or so. I would hate to have to use it only to find out it is flat.
#5 ·
yes, it is a bad idea to mix in a new tire with 5 year old tires.. (unless they have less than 10,000 miles on them).
However, my car has a donut spare, not even close to the size of the other tires. Subaru says its only for a short distance, not more than 50 miles, and low speed.. They also say to only use the mismatched tire on the REAR. If there is a flat tire on front, then a rear tire moves forward first, then the mismatched tire goes on the back..
2/32 difference is the maximum tread difference for full time use.. it takes me 10,000 miles to use that much tread.
US-spec manual says you can run the small spare up to 50mi (80km) at reduced speed. The mini-spare is ~10% smaller diameter than the standard tire.
A few/32s is a much much smaller difference.
I would put the 'bigger' tire on the rear axle and run it at a lower pressure than the other three; e.g. 30 vs 35psi.
YMMV.
