Hey everyone, Mike here from CARiD. As your vehicles get some miles on them, one of the best things you can do is regular oil changes. While you can always take your car into the shop, doing it yourself at home is often much more affordable and satisfying.
I put together the list of some handy oil change items (all the basics you need - oil, filter, drain pan, etc). Doing it in your own garage only takes about 30 minutes or so once you get the hang of it. Just make sure to refer to your owner's manual on the oil grade and capacity your manufacturer recommends.
The products listed below will make the oil change hassle-free and less time-consuming. And we have exact fit oil filters for most vehicles to filter out contaminants.
Check the links below for some options that can work for your ride.
First Things First - Oils & Oil Filters
Engine Oil Filters & Parts | Housings, Adapters, Gaskets — CARiD.com
Protect your engine from dirt and expensive damage. Our high efficiency, large capacity engine oil filters remove the smallest particles to keep engine oil clean.
and
Motor Oils - Synthetic, High Zinc, Conventional | CARiD
No matter what you drive or how you use your vehicle, we have the motor oil to protect your engine, including synthetics with the latest lubrication technology.
Handy Tools you May Need:
Performance Tool® - 2" to 5" Self-Adjustable Oil Filter Pliers
Performance Tool® W54312 - 2" to 5" Self-Adjustable Oil Filter Pliers
Universal 2" to 5" Self-Adjustable Oil Filter Pliers - Part Number W54312 by Performance Tool. Available in Automotive Tools Department at www.carid.com
- Size: 2" to 5"
- Perfect solution if you have multiple vehicles to work on
CTA® - 8 in 1 Oil Drain Plug Wrench
Universal 8 in 1 Oil Drain Plug Wrench by CTA®. When it comes to quality, CTA knows no compromises. All the products made by this stringent quality control conditions. The latest manufacturing methods coupled with the use of the highest-grade materials ensure the closest tolerances are adhered to.
Square: 8mm to 17mm
Hex: 12mm to 19mm
Lisle® - 4.5 gal Oil Oval Drain Pan
Lisle® 17982 - 4.5 gal Oil Oval Drain Pan
Universal 4.5 gal Oil Oval Drain Pan - Part Number 17982 by Lisle. New Drain Pan Design Provides 60% Larger Catch Area for Easier Fluid Draining. Automotive Tools.
Mityvac® - Pneumatic Fluid Evacuator
Universal Pneumatic Fluid Evacuator by Mityvac®. Investing in the right oil change tool is crucial to properly maintain your vehicle and ensure its efficient operation. This superior product is just what you need to complete a successful oil change. Designed with great precision and manufactured...
View the full list of oil change tools for your specific model on this page:
Oil Change Tools | Filter Wrenches, Drain Pans, Sockets, Pliers — CARiD.com
Changing your oil isn’t a chore when you’re equipped with the right tools. We have a wide range of filter wrenches, drain pans, funnels and lubrication equipment.
If you run into any questions on the process or products, just let me know.
