EGR Valve, how to test it? & what causes the carbon
1 reading
39K views 17 replies 4 participants last post by  plain OM
If you remove the battery you often need to do an “idle re-learn” to get the idle stable again. I am not certain if this will solve your problem but it is probably worth doing just to eliminate this as a possibility.
Do a forum search and you should be able to find the exact procedure but from memory you turn off all electrical accessories including internal fans and lights, disconnect the battery for 10 minutes and then after re-connecting the battery, start the car and without touching the accelerator or turning on any electrical accessories, let the car idle for 10 minutes.
After 10 mins turn the car off, wait at least 1 minute and then restart the car, again without touching the accelerator or turning on any electrical accessories and let the car idle for 5 minutes.
Turn off the car and wait 30 seconds.
I had to run this procedure on my daughters 2007 Legacy/Liberty after changing a battery and it resolved the problem straight away.
Seagrass
