I screwed up. I drained about 5 qts of the transmission oil from my Outback thinking I was draining the engine oil. I know. I'm trying to learn.
I've done so much research, and talked to a few Subaru mechanics. I bought everything I needed to refill the tranny oil myself. Finally got under there to start the process (I know it's a very specific one and I'm confident I can do this).
Only issue is I cannot find the fill hole. I really REALLY thought I had it pinpointed, but once I popped the bolt off, there was some weird metal bolt thing in the way of the hole. Now I'm not sure if this is even the fill hole anymore. I don't want to try tearing this weird bolt out or mess with it until I know what it is.
Does anyone know what this is? Is it really the fill hole? Do I need some special hose now to pump transmission fluid in? Nothing is going past that bolt thing, and I don't know where else to check.
Can anyone confirm that this is indeed the location for filling the CVT fluid, or not? Does it even exist anymore? Also does anyone know the model # for the transmission itself? Maybe I can find a diagram soon.
PIs pls help this dumbass. I'm kicking myself over this huge mistake. Any help is appreciated
Photos:
Image of the (US) passenger/ right side of the transmission. I read somewhere that Subaru moved the fill hole from the driver's/ left side wall (where it used to be) due to rerouting of the exhaust. I took this at face value because if the fill hole IS on the driver's side, it'd be really hard to get to.
Photo on the same side after I removed a plastic cover that was partially blocking the fill hole
Closer photo of what I thought was the fill hole
Photo of fill hole after I removed the bolt. Not sure what this weird metal shaped thing is, but no fluid will pump through it
Extremely intimate close up of the metal thing that's blocking my fluid from pumping deep into my car
Photos:
