Had my transmission changed out by the dealer and the drive shaft is rubbing on the heat shield. Looks to me like the carrier bearing is upside down, when I compare it to pictures on the web. It is also deteriorating, at least on the surface, the dog ears with the bolts are clearly stressed being at the opposite angle than they were designed and the shaft is displaced out of it's normal position.
So now what?
-- What other damage should I request they look for? (seals at each end of the drive shaft?)
-- Having run 4K miles in the wrong position since the transmission was changed, should I request a new carrier bearing and/or anything else?
So now what?
