Interchangeable Parts From Other Subaru Models That Will Fit A 4th Gen Outback
4.6K views 1 reply 2 participants last post by  Fasty67
Hey guys, I am looking for OEM Subaru parts that will fit a 4th Gen Outback. What I am doing is lowering my Outback and I would like to have better handling, better brakes, or anything else that can fit my OB. I know about the 08-12 STI rear sway bar mod and I would like a bit more info on it. I like the idea of putting interchangeable parts on my OB to make it more unique. I also plan on doing a Legacy GT front end conversion sometime after I lower the OB. If anyone knows any other parts, specifically WRX, STI, Impreza parts, that will fit my OB and make the overall ride quality better please let me know!!
08-14 sti bar is 19mm and bolts right up. The 15+ rear bar is 20mm and also bolts right up. You just need the matching bushings for the bar. If your car is a 2010-2012 you can also put the 2013/2014 front sway bar on to increase from 24 to 26mm. Make sure you get it for the correct engine as they are different.
Not an expert on lowering but you'll probably want the rear upper arms for the legacy for camber correction. There are some good threads here on this topic. Look for the dropped 4th gen thread. There is a thread that pretty well details the few most common methods for lowering the OB. Advanced Search is your friend.
