Leaking Camshaft Cap
17K views 10 replies 5 participants last post by  aesthetic.rake
The leak is very likely caused by not putting enough ultra gray or fujibond on the cam cap when installing. I would not want to try removing cap cams on the vehicle. Could you try running a bead of ultra gray or ultra black underneath the cam cap along the seam?? It might work better than the spray sealant.
