We have no heat in a 2009 Subaru Outback. It doesn't seem to be a coolant, thermostat or heater core issue so I am assuming it is the blend door. Air always blows cold but I can switch between which vents are blowing.
Can anyone tell me which part I need to replace? There appears to be two separate pieces that are called similar names. Do I need the HVAC Blend Door Actuator or the HVAC Air Inlet Heater Actuator?
