Anyone have or have installed the OEM starter ? Ordered one and i'd like to see if its something that i can do myself.
one thread is enough, no need to post in more than oneDOUBLE POSTING
Hi, I'd like to bump this conversation, as I am about to do my install myself and I'd like to ask for tips/tricks on removing the a-pillar since I definitely do not want to damage the side airbag. Do I go at it from the top portion of the trim and start prying? Also can someone please clairfy if I am removing the bolt to disconnect the battery cable? How is this different than removing the negative terminal from the post?
Everything else seems quite explanatory, I guess but any other tips/tricks would help as well.
I think the parallel wire is only a power circuit for the battery sensor itself... don’t think it provides any other electrical grounds (although I haven’t looked it up in the schematics.. this was just from reading about the redesigned battery monitoring system for the Gen5)Wouldn't necessarily call it "easy" on a Gen 5 if that sensor is so prone to damage and other installation problems. Interesting trick, never heard of that one. Guess removing just the ground cable still allows power to some circuits?
there are some good instructions in the PDF. With pictures and torque specs.I don't think anyone answered my question: am I only removing the highlighted bolt to disconnect the battery cable and not removing the entire negative terminal from the battery post?
