Question for the oil burners - when does your light come on?
1 reading
14K views 15 replies 11 participants last post by  jdmorris
Question for the oil burners - when does your 'low oil' light come on?
I just did the third oil change on my oil consuming 2014 6MT and have learned that my low oil light seems to come on prematurely. I've now had 3 separate intervals when the light turned on and each time the oil was half way between the full and empty holes. How much oil is on your dipstick when your warning light turns on?
Here's my history:
Purchased car with 30 miles, oil well under full from the factory.
2000 mi - low oil light; topped off.
2500 mi - break in oil change
6500 mi - low oil light ; topped off
7500 mi - oil change (planning on 5000 mi OCIs for the time being)
11500 mi - low oil light ; ignored it this time
12500 mi - oil change
I'm debating whether to go to the dealer to see if there's a fix. If there's a quart from the low to the high mark on the dipstick, I'm not burning too much oil (more than I'd like, sure, but half a quart in 4000 miles isn't terrible). However, the low oil light is the sort of warning I usually pull over for immediately - each time it has happened I've been in the middle of nowhere on a road trip digging for that spare quart stuck under all my tightly packed gear in the spare tire well... If I'm only down half a quart that seems really dumb. This last thousand miles I just checked regularly to make sure nothing bad had happened but the oil stayed well above the bottom fill hole and on short trips the oil light wouldn't even turn on.
JD
^^^^what he said...I opened this thread expecting a post from someone in the UK or Australia...our true oil burning OB drivers...:wink2:
That sounds about right. My oil light starts coming on intermittently at slightly over 1/2 qt low which near that half way point between the holes on the dipstick. In 2015 they changed the point at which the light comes on. I assume they can adjust it on 2013/2014's but I never pursued it.
#5 ·
There is a Technical Service Bulletin (I don't have the # offhand) to replace a sensor. My '14 6MT also burns oil, but the last time I brought it in the dealership said it's b/c the sensor prematurely caused the light to turn on. Unfortunately I don't recall exactly what the oil level was at that time, but regardless I got the sensor replaced at around 12,000 miles. It's a special order part, and likely will require two trips (one to diagnose & another to replace, unless you can convince the dealer to just order the TSB part over the phone).
Most recently, the light came on about 2,000 miles after my most recent oil change. I'm going to wait until after 20,000 miles to see if the engine settles in more before asking for an oil consumption test, but yes, the light came on when the oil level was right at the lower hole, at which point I put the quart in. I do check it every month and probably should add it whenever it's 1/2 qt low (as I did early on) but with this TSB fix I'll probably just wait for the lower dot/light (whichever comes first) and put a full quart in.
Following my first oil change (1,500 miles) after I picked up my 2014 2.5i 6MT Outback she would burn about 3/4 to 1 quart of oil every 2,000 miles. After 6 months and many visits to the dealer Subaru was nice enough to give me a new short block. If it's consistently burning that much oil I would bring it into your dealer and have them at least check it out.
It sounds like TSB 11-149-14R: Reprogramming File Availability for Oil Level Detection (Dec 1, 2014) might cover this. I can't find a copy of that TSB available (for free) online, though.
From the FB25 oil ring TSB 02-157-14R Page 3 of 25:
As related information, the low oil level warning light (on models so equipped) is designed to illuminate when the engine oil level in the sump drops below approximately 4 quarts with the engine not running (engine is 1.1 quarts low on oil) and 2.4 quarts when the engine is running.
So in theory the light should come on when the oil hits the low mark on the stick and the other TSB means this may be a known problem (thanks, Deep Indigo!).
I never had an oil light come on. But if I did, I would expect to hear a simultaneous death rattle from the engine..
But if I had an outback that consumed engine oil, I would check the dipstick frequently and not rely on the idiot light.
This thread isn't referring to the old-style "low oil pressure" idiot light that is famous for coming on just in time to let you know your engine just got toasted. These guys are referring to the 'low oil level" warning light that the newer cars are equipped with.
#14 ·
LoL, 4whl +1.
A dipstick is impossible to be accurate across all demographics, it requires users know how to use it (you have to wipe it off first). With a light/sensor, you can add a software algorithm to it (before it hits the low too-late mark).
For some folks, filling gas is maintenance.
#15 ·
LoL, 4whl +1.
I once came upon an aquaintance of mine in the shopping center parking lot, late at night. He had an old pickup, and the hood was up. So I stopped and asked him if he needed help. No.......Just drove over for a flat spot, with a streetlight, so he could check his oil level.
Sometime later, while we were playing poker, I mentioned to him that he could put an extra mark on his dipstick so that he could read the level on his unlevel driveway. All that was necessary was checking the level in the spot he always parked it, when he knew it was full......And add a mark on the dipstick at that point. I tend to premeditate laziness.........
Random update - I had the TSB performed on the car as having the oil light come on every 1500 miles when it burned through half a quart was annoying, so when the light came on this last time I brought it in. The dealer installed a new oil level sensor, refilled the oil (no change, no filter, but 3 new quarts) and reprogrammed the ECU. I believe the ECU reprogramming had other, positive driveability effects on my 6MT but until I pull the new ROM and check to see how much is different I'll chalk it up to placebo.
JD
