A few days ago my 2000 Subaru Legacy Outback (192k miles, 4-cylinder, automatic) started having troubles with its electronics.
First, the rpm gauge and speedometer would flatline (as if they had briefly lost power) and then return to where they should be. This could happen multiple times in quick succession. Next, my radio lights would flicker or the radio would shutoff entirely, often this would happen in conjunction with the dash problems. Yesterday on a longer trip (about 30 minutes), half-way through the trip the gauges had flatlined permanently, the radio had shut off, the odometer was off, the windshield wipers moved slowly, and the ABS light had come on even though I was not actively braking or was in a scenario where ABS would activate. At one moment, the ABS had grabbed lightly even though the car was coasting. I was not pressing the brake or accelerator. A few minutes after that had happened, the power had completely returned to the vehicle but the check engine light had come on along with the battery light. The battery light shutoff a few minutes later and has not returned since. I have not had any engine, steering, or brake issues.
The car only had trouble starting at once, and it still started, albeit a bit slowly. Other than that, there have been no signs of battery/starter issues.
The diagnostic steps I've taken so far are:
I've had the battery checked and it was fine. It was also replaced recently.
I've had the alternator checked before the check engine light had come on, and the worker at O'Reilly's said it was fine but I have my doubts. I am going to have it checked again tomorrow. Everyone I have talked to, including myself, believes the alternator to be the problem even though the test said it was ok at that moment in time.
I am not a genius when it comes to cars, any help or suggestions would be greatly appreciated.
