I dont see any reason NOT to run synthetic, but, Im not an expert YMMV
> synthetic's flow properties with extreme climates
you mean the superior flow properties of synthetic worry you?
> It's been proven that some engines with higher miles will leak or seap when switched
makes sense if the leak was filled with carbon and sludge from the dino oil, the synthetic will clean that out and reveal the need for new gaskets
I use Shell Rotella T6 5w40 in a 99 Impreza OBS, 85 Vanagon with stock motor, 86 Vanagon with Subaru 2.2 motor, 87 Vanagon with 5Cyl Audi A6 Tdi motor, 03 Jetta 1.9 Tdi, and my 06 Outback with 3.0R motor.
I have not had any Cat issues, nor seepage issues, but Ive only been on the T6 for about 6 years, for a total of about 300k miles combined, 2 daily drivers, me and daughter.
from this thread (turbos running T6):
this guy runs an STI:
"I use Shell Rotella T6 5w-40 which is a synthetic. Here's my latest oil analysis, and I used the same oil on my last analysis. I'm stage 2 protuned to 316WHP."
this guy runs a Forester 2.5 XT
"If you check your manual, you'll see that Subaru has no problem with synthetics as long as you still run the proper viscosity and oil change interval for your conditions. According to recent emails from SoA posted at nasioc, SoA will be requiring synthetics from 2011 onwards and recommending them for all previous years."
