2010 Subaru Outback Creaking noise when turning
1 reading
2.6K views 3 replies 3 participants last post by  SMR
Hello everyone,
My girlfriend's 2010 Subaru Outback (CVT) started making a creaking/popping noise when making corners, I only notice it at low speeds and tight corners.
The sound definitely comes from the front passenger side wheel and is the worst when making a sharp left turn such as a U-turn. When making such a turn it you can 'feel' the noise as if the wheel is getting stuck on something during the turn. Is this a sign of a CV joint or something worse?
I am planning on taking a look at the CV joint but was just curious if anyone had some experience or insight with this issue, I've read that it could be caused by something much worse like a failed VC. :(
There was a weird thing that happened prior to us noticing this issue. We parked on a slight hill (facing downwards) and engaged the parking break, then later when we left we disengaged the parking break and shifted into D only to have the car stuck not inching forward as would be expected. We tapped the accelerator and the car sort of lurched forward a bit with a pop noise that I knew couldn't have been good but nothing went wrong after that. The creaking noise was noticed after an hour of freeway driving when we pulled into the parking garage.
You are describing classic CV joint failure. I have zero experience with CVT other than driving my exwife Nissan for several thousand miles. But sounds like a CV joint. Thet get crunchy when turning and typically no noise going straight. Unless they get really bad.
Sent from my SM-G965U using Tapatalk
Sounds like you are describing a CV joint issue. More investigating is necessary.
As for the way it acted on the hill, it could have been a stuck park brake shoe or caliper binding at a wheel.
Nothing you've described sounds like it's CVT related.
Thanks for the replies, some brake part getting stuck was my suspicion as well. I went and looked under the car today and what do you know the CV boot is sliced open haha.
