Ok, so took the car on a little trip from Orlando to Charleston SC and back. With less then 100 miles the Christmas tress dash came on. Lucky I had my scanner with me and looked at what was going on, on road side. Came back with a P0442, small leak code. 1 confirmed, 1 pending. Cleared them and went home. Digging into the problem it sounds lie a purge valve is bad. It is rough idle and stalled out when I chawed from drive to reverse. Gas cap is fine, drove about 350 miles after getting gas, no issues
Scanned it just now and it is only showing a P0442 pending code, no CEL. Two part question 1) is there a issue there or no, because it is not coming back up a a CEL?? Does it need to go through a few ignition cycles to show up/clear?
2) Where is this stupid purge valve and how hard is it to actually replace? Thanks
