I have seen people on here suggest that you can suck the fluid out with a turkey baster and replace it with new fluid if you do not want to go through the trouble of the full procedure.
No no
NO!!! (Not for the brake fluid)
Changing the fluid in the master-cylinder does
nothing for the rest of the brake-system. The same old crappy fluid will remain in the piping, ABS unit, and calipers.
Lets not forget that the brake fluid DOES NOT circulate. It moves no more than 1/2 inch back and forth as the brakes are used.
Infact, the condition of the brake fluid in the MC (
even if tested)... does not tell you condition of the rest of the system.
With that said, perhaps you are thinking of a hydraulic Power-steering system. (Which does circulate). In this case, one could suck out from the reservoir and put in new. This would replace about 1/4 of the total displacement of fluid.
If this was done every couple weeks... after about 6 changes, there would be over 80% new fluid in the system. The math to calculate how much old fluid is removed each time tells us that one would be replacing less of the old fluid each time. (because of mixing) The math also tells us it is IMPOSSIBLE to change
all the fluid by doing partial changes.
