2,241 - 2,260 of 2,260 Posts
The designs were something that I had in mind. A local vinyl wrap shop in Portland, OR made the topographic map and a friend of mine did the mountain, trees, and stars on my vinyl cutter. The shop then incorporated both designs into one. It has been on there for a little over 2 years now and it still turns heads and catches people's eyes no matter where it goes.
Almost back from a 5k mile road trip. Highway mileage was 26.5 mpg on the uphill leg at mostly 80mph, 28.5 on flat legs at 80, and a best of 29.5 on a mostly down hill leg. It does better at 70mph though. Also, these numbers are calculated from odometer miles and gallons to fill up, not the computer. This cars speedometer/ odometer is pretty accurate or less optimistic because it has tires that are 1/4 inch taller than stock.
2013 3.6R Bought new, drove it 250 miles home and got almost 30 mpg. Over the last ten years, city driving has averaged around 18 mpg, and highway in the 22-25 range. If I’m not in a hurry and tag along behind a semi, I can hit 28 mpg. At 160k miles, I replaced all four wheel bearings, replaced the original plugs, changed the transmission fluid - and managed to get 30 mpg on a 200 mile trip! Otherwise, 18 city/23 hwy is the norm.
I know I started driving with somewhat of a lead foot (AWD allows for it hehe), but with a wife that's easily made car sick (and two dogs usually trying to stand up half the time), I've long since adapted, and now most would consider my driving to be quite reserved, especially in transitions of both speed and direction.
With all of that said...
The average MPG I'd get on the 2014 3.6R I bought, when new and on typical street tires, was still only about 25 avg.
Now with all the added weight, heavier duty tires, etc. (in my signature), I'm happy barely holding at 19MPG. Half highway and half of what I guess is similar to city but completely off-road, so between low speed to low-medium and back, plus the fact that the "highway" miles are extremely vertical and sharp roads, so constantly switching between braking down to 35, then accelerating up to ~60, only to return to 35 within less than 30-60 seconds.
Luckily, gas is so cheap down here, that even at 19mpg, I can afford to buy 91 or 93 octane for cheaper than 87 costs almost anywhere else in the US 😁
Kindest Regards,
JD
2013 2.5i Premium with 107,500 miles. As soon as my car hit 100k, my gas mileage went to ****. In the city: 17-19; on open highway with 55-65 mph, I get 19-22. I used to get 25 in the city and 30-32 hwy. The dealership told me its because my driving habits changed (which is a weird thing to happen all of a sudden and weird thing for them to assume) and that there's nothing they can do.
Does anyone have a recommendation about diagnostics or fixes?
I buy high mileage Subarus, one thing that consistently effects all of them is sludge buildup in the intake manifold from the PCV, the crankcase venting oil into the intake. Also the carbon from the valves eventually start constricting the intake also. The valves get loaded with crap too. Also poor fuel, un-combusted gas, oil vapors, etc start clogging up the cat converters. Old wheel bearings don't help either. There are bottles of cat converter cleaner you can get that might help, also taking off the intake manifold and cleaning it out helps. Personally I dump seafoam down the spark plug holes, pour it down every intake port, etc and let it sit over night. I leave the spark plugs out and I crank it over so it sprays all that stuff out and it's nasty. Makes a mess but it's worth it. Do it outside if you try, and before oil change. Also right before an oil change, add some sea foam or block cleaning additive and let it idle for a few minutes before you change the oil. That cleans all the sludge out of the block. K&n air filters work nice, clean your mass airflow sensor with mass airflow sensor cleaner. In most importantly, switch to full synthetic oil if you haven't already. Also replace the oil in the differentials with full synthetic. Higher performance spark plugs work nice too. Sometimes new 02 sensors help, depending. If you do all that, you're going to feel a tremendous difference in torque and power, most of all, gas mileage will be up again. Might even be better than your original gas mileage at low miles.
I’m going to have to try this at my next oil change. Right now I average 20mpg and I don’t think I’ve gotten above 22 since owning (bought at 145k). I put in a new Pcv valve and cleaned the throttle body so far..
Compression test if you can, I'm about to do this 2012 outback 6mt I just picked up 2 days ago, I'm going to do everything I mentioned above on this one now. I'm noticing a lot of sag in the ass when I shift gears. I bought cheap strut stabilizers that spread the struts and makes suspension tighter. That might help with getting more torque to the wheels instead of suspension absorbing some of the energy. (Theory of mine). I'm getting 20mpg and it's throwing a code for p134 front 02 I think, I got one ordered. I'm going to see if I can get in the ECU with my tactrix and datalog, check AVLS, etc, maybe advance timing a little, Subaru is very conservative but this is dangerous. good luck with yours as well 💯👌
2014 2.5 premium just over 110K miles, had it since new.. Haven't seen over 30MPG avg, but usually close (on trips).
Comically on our last long trip.. we drove separate cars...450 Miles consistently over 80MPH, the wife's 2014 2.5l CVT Outback got 28.6 for the trip, my 2003 Corvette (6speed manual 5.7l LS1) got 28.7 MPG. My analysis, the low slug aerodynamic Vette uses less HP to maintain 85MPH, as the engine loafs along at around 2000 RPM while her 2.5l was peddling hard to push a high profile brick, and the CVT had to downshift going up hills.
We tried the 89 Octane E85 a few years back driving thru Iowa and Nebraska.. yeah it's a couple pennies a gallon less, but the fuel mileage suffered about 10%, so that was a 1 time experiment
I think my MPG has went down over time
I don't really know what impacts it
my speculations:
1. Car wear
2. Gasoline gets more corn
3. CrossClimate tires
181K on my 3.6R and I know I can tell a difference between the (now way more expensive) ethanol-free fuel and the normal E10 gasoline (also beware there's now stations selling what they call "regular" fuel 88 octane that is actually E15 unlike the actually-normal gas most places sell as E10)
I find I'm getting around 24MPG vs the 26-28MPG of years ago but its hard to compare because also speed limits have gone up and traffic is SO much more aggressive now...I know my car seemed most efficient around 62-63mph and was easy on 55mph roads but these days that's way too slow on most highways being raised to 60 with traffic doing 70+ on state highways and 80+ on interstates plus you get run over and cut off coming up to stops requiring harder braking.
I'm running CrossClimate2 tires
