So,
I recently took the Outback to the Stealership.
I say this because they are in business to make money, and it seems to make it no matter what.
Ive 82k on our 2013, and I've done the following myself:
- change out the brake fluid
- change the air filter
- change the cabinet air filter
- change the 3.6R ATF
- change the front and rear diff fluids
I walk into the dealer and tell the service rep that I don't want to hear that they need to change the ATF, or flush the brake fluid, etc. More to the point I don't want to see anything on the vehicle report indicating anything needed to changed without scientific proof (eg chemical testing, etc.)
What I previously noticed is that they like to decide to change stuff based on the schedule and not actually based on observations. The prior time I took the car to the dealer i had indicated that I had just change the ATF, and that it did not need to be changed. I got a telephone call from a dealer saying the tech says the ATF need to be changed. So then I asked all sorts of questions: how did the tech arrive at that conclusion? Does the fluid smell burnt? Does the fluid look excessively dark? What chemical analysis was run on the fluid?
I then informed him that I had just changed the ATF and that it was in flawless condition and that I did not appreciate someone trying to make money off of me by telling me it needed to be changed. I also indicated that it better not be on their service documentation with an indication that it needs to be changed. Of course what happen when I got the paperwork: it indicated the ATF needed to be changed.
This most recent time when I told the guy the brake fluid was flushed, and I told him I did it myself, he attempted to give me a hard time in implied that I didn't get it out of the brake calipers. So I turned it around and said " are you telling me that when I replaced the brakes and reset the calipers, somehow the fluid mysteriously stays inside the calipers?"
Bottom line is that my experience with the dealer is that they are trying to make as much money on you as possible and they will do it by replacing stuff but does not need to be replaced.
With Subaru the schedule is basically there to ensure you're car is properly taken care of, while the dealers use it to take advantage of the situation and make money.
For example: if you're driving on the highway back-and-forth to work every day and you're putting lots of mileage on your car that does not mean that you have a severe service interval. It actually means that you can rotate the tires at 10k ( The previous service manager told me that...)
Another example:
Almost every automotive manufacturer says that your oil should be changed at 6500 to 7500 miles. Almost every dealer will tell you to change your oil at 3000 to 3500 miles. This is because they can make a lot of money on oil changes . Screw the environment - who cares about that, let's create a lot of waste oil for no reason. If Subaru wanted the oil changed every 3500 miles they would tell you that. Unless you live in a desert there is no way you need to be changing your oil that often. And if you live in the jungle make sure the car just operating temperature at least three times a week...
Most dealers, especially in urban environments, where people don't know how to do the work themselves, will take you to the cleaners monetarily.
There are some things I don't feel like doing myself, and then I'll use the dealer to do it. However, the mount of money that you can save by doing small jobs yourself is quite substantial.
I also agree with coming up with a detailed list and presenting it to them.
Oh, and the ATF thing, they claimed it had to be done using a special machine. When I called Subaru directly and asked them what the deal was -> I eventually got an engineer on the phone who told me just drain 3 quarts like it says and put 3 quarts back in. That's the only thing you need to do ....
