Check engine light - air fuel imbalance
3.9K views 6 replies 3 participants last post by  jdubyk
At a loss for how to move forward with this check engine light error. Ive been trying to diagnose it for about a year. I use the blue driver OBD2 reader and get the following code: P219E
what I’ve done so far:
  • searched for a vacuum leak, cannot hear anything, nor does the propane tank technique do anything. I’ve also tried starter fluid.
  • cleaned throttle body
  • cleaned MAF sensor
  • replaced EGR valve
  • replaced Spark plugs
  • replaced PCV
  • replaced fuel filter (pain in the butt)
  • replaced O2 sensors
anybody have any other ideas?
can runs poorly when cold, sort of stumbles. Once warm it smooths out.
fuel trim is usually plus 8-12%, regardless of engine temp.
I’m stumped.
Jon
Battery - needs to output what the CCA rating is or better.
Grounds - main needs to measure at 0 ohm from the negative post to the end of the cable down by the starter; no more than 0.1 between negative post and alternator case.
ECT - check it's output with the engine cold to see how close it is to the ambient temp.
Intake Air Temp - same as the ECT, check that it is close to ambient with engine cold.
Fuel - pressure with key on, engine off should be 49-58 psi.
Fuel injector - Measure the resistance between fuel injector terminals 1 & 2; 5-20 ohms depending on the injector temperature.
Check power to the injector - should be battery voltage with key on, engine off between terminal 2 of the connector and engine ground.
With engine running, you should have a ground signal on terminal 1 of the injector.
Check the coil is firing.
Is there any noises occuring when you first start the engine?
Is it full of clean oil?
What brand spark plugs did you use?
How many miles in the car?
What brand O2 sensors?
Will begin working through some of your suggestions.
125k on the odometer
Denso O2 sensors
NGK iridium plugs
battery is good
oil is good
all coils are firing
grounds are good
no engine noises other than the occasional sounds that accompany an intermittent rough idle
how does one go about measuring fuel pressure easily?
thanks for the thoughts. I’ll check resistance and voltage at the injectors and temp sensor outputs
#5 ·
How did you check the battery, and how did you check the grounds? If you check the battery with a multimeter and it's measuring over 12 volts that does not mean that it's providing enough amperes.
To check the fuel pressure, you have to have a fuel pressure gauge and the adapters to tie into the fuel hose at the line.
