I have a CEL lit. It comes on only if the engine tachs above 3-4k, and stays on forever, including the next drive cycle. If I clear the lamp with the engine off, it will come back on after I restart the engine and rev it a little or drive about 100 feet. If I clear the lamp while driving, it stays off forever until the engine is cycled again. Here's the kicker: There are no codes stored. My code reader says everything is fine. It will say everything is fine for the next 130 miles if I let it.
Once upon a time, I got the code for the evap solenoid, so I plugged together the green diagnostic connector under the dash and took apart the whole carbon canister assembly behind the passenger rear wheel. The solenoid cycled correctly every 1 second and everything checked out with my meter. I then disconnected the green connector and replaced all the parts back up under the rear end, and cleared the code out. My CEL then came back on, and it gave me the knock sensor low code, but only once. Ever. It's been absent since then, yet my lamp keeps coming back on...
Any thoughts on this one? Is my ECM on the fritz? Am I on the fritz...?
