Anyone else planning on adding a dashcam to your rig? I plan on getting a Blackview dual Camera system with the hardwire kit. Just wondering where everyone plans to or has mounded the cameras? Pictures would be AWESOME.
Which is what I meant when I said it's keyed power in the post directly above yours, from 2 weeks ago...I'm pretty sure that outlet will turn off when the car's turned off,
My bad! I meant to reply to 22Wilderness's question, not your post. (Wasn't sure if 22Wilderness would catch the keyed power statement.)Which is what I meant when I said it's keyed power in the post directly above yours, from 2 weeks ago...
Here are some photos. I couldn't go any higher since then I would capture the mirror mount in
the video. I didn't want to go any more left to go higher to stay out of eye-sight way.
pcthe View attachment 472853 View attachment 472854 View attachment 472856 View attachment 472857 View attachment 472858
I might be wrong on this, not having looked at that adaptor, but I believe you'd lose Parking Mode, as the dashcam wouldn't have a power source once the engine is shut off.I've been lurking here for a while. I recently replaced my 2012 outback for a 2022 outback with a dimming mirror. Has anyone tried adaptors that power the dimming rearview mirror to use to power the dashcam? This avoids running wires everywhere.
For my car model this is the adaptor that would work supposedly work.
Dongar power adaptor
What do you guys think about this?
You are correct, since the outback stops powering the device after the engine turns off and the driver door is open.I might be wrong on this, not having looked at that adaptor, but I believe you'd lose Parking Mode, as the dashcam wouldn't have a power source once the engine is shut off.
I talked with Garmin yesterday and they said a lot of the non-Garmin cables overheat so they could not recommend using Dongar power adaptor. Can you confirm/disaffirm this?You are correct, since the outback stops powering the device after the engine turns off and the driver door is open.
For those curious, I did get the adapter and it works with the 2022 outback wilderness powering both the dimming mirror and my dash cam.
@ChaIto Can you take a photo of the adapter plugged in? Where did you plug it in? I got the same adapter and it didn't fit, at least as far as I could tell.You are correct, since the outback stops powering the device after the engine turns off and the driver door is open.
This seems like a super easy install for a front-only dashcam with no parking mode. I wonder if there's any downside since you've installed it?For those curious, I did get the adapter and it works with the 2022 outback wilderness powering both the dimming mirror and my dash cam.
Is there a reason, except for more wire concealment, that you removed the ES housing? Most of the installs I've seen just remove the stalk cover, make their connections and then double side tape the USB socket to the stalk cover.Just installed a Garmin Dashcam Mini2 in my 2022 OB Touring XT. Mostly as a temporary unit till the good ones arrive (gonna install Full HD in both vehicles once the weather is nicer).
Surprisingly simple to run the wires properly down to the glovebox for power.
Took approximately 20 minutes work for each car. Most time was spent trimming the stalk cover to hide the cable inside. I'm pretty anal retentive about my cars. Hope the pics do it justice. Feedback welcomed.
View attachment 532598 View attachment 532599 View attachment 532604 View attachment 532605
I don't think he used a Dongar adapter. He ran a USB cable from the dash cam up the stalk to the ES housing/headliner, and then, I imagine, across and down the passenger side A pillar to the glove box outlet.Is there a reason, except for more wire concealment, that you removed the ES housing? Most of the installs I've seen just remove the stalk cover, make their connections and then double side tape the USB socket to the stalk cover.
I'm about to pick up one of these Garmin because it's a name brand that I know. Can you explain a little more or show how you ran the cable down for power and what cable you used. Thank you.Just installed a Garmin Dashcam Mini2 in my 2022 OB Touring XT. Mostly as a temporary unit till the good ones arrive (gonna install Full HD in both vehicles once the weather is nicer).
Yeah the install was easy, and I just taped the extra converter thing on the outside of the black casing. I don't really care about parking mode, so its fine the way it is. It looks clean and it does what it's supposed to do, feed power to the cam when the car is on.This seems like a super easy install for a front-only dashcam with no parking mode. I wonder if there's any downside since you've installed it?
