Detailed instructions or Gen 6 CVT fluid drain & fill?
1 reading
17K views 28 replies 12 participants last post by  TurboWagoon
Hello,
We're looking for detailed instructions for the Gen 6 (2020) CVT fluid drain and fill. In particular, photos or drawings identifying the drain and fill plugs would be excellent, as well as the fill temperature approximate fluid amount and the Subaru fluid required for the 2.5NA Outback.
I haven't been able to find a detailed write-up so far. Hopefully someone can point us to it.
We've been through the process on our 2010, which I think has some similarities, so the process, itself, isn't too problematic.
Doug
#5 ·
For the 690 CVT. Double check it is the same.
2. CVTF
A: INSPECTION
Check for leakage of CVTF from transmission.
B: ADJUSTMENT
CAUTION:
• CVTF level changes along with CVTF temperature. When inspecting CVTF level, observe the specified
CVTF temperature.
• Always use specified CVTF. Using other fluid will cause malfunction.
1) Idle the engine to raise CVTF temperature to 35 — 45°C (95 — 113°F) on Subaru Select Monitor.
2) Operate the select lever in P → R → N → D and D → N → R → P to circulate CVTF with the engine idling.
3) With the engine running, lift up the vehicle and remove the filler plug.
CAUTION:
Pay special attention to the following operations as the engine is at idle.
NOTE:
CVTF is at the specified level when it is up to the filler plug hole lower section.
(A) Filler plug
(A)
(A)
AT-07748
If you drain hot CVT fluid out and refill with "cold" CVT fluid you have overfilled the CVT. Hence, the need to have it at 95 - 113 degrees.
#11 ·
I know this is old, but, yes, it is the same.
BUT, note that if your OB has a radiator style cooler in front of the AC heat exchanger (aka: AC "radiator"), then take special care to double check the fill by repeating the process, or do an initial fill that closely matches how much you drained, as the fill procedure, due to filling the lines and radiator, may cause it to overflow out of the overflow port/hole when it's not actually full.
In the Ascent world, I've followed a few drain and fills where that has happened causing the CVT to be a couple of quarts low. Same applies to the Gen 6 OB Turbos with coolers.
If you have the XT the transmission is different. The fluid is not as readily available in quantities small enough to make it worth your time and trouble. But I found it fairly easy to change on My Ascent that had the same transmission.
Step 1. Make appointment with dealer and find out how much it costs, also try to get a loaner car lined up
Step 2. Leave your car at the dealer and take loaner car
Step 3. When done return loaner car
Step 4. Pay the dealer and get your car back
I'll add my $0.02 to the discussion. I have a '24 OBW with just under 10k miles. Decided to complete CVT drain/fill to (a) remove any suspended particles from a new CVT; (b) gain experience; (c) satisfy my curiosity about condition of CVTF at 10k miles.
Results: (1) Drained approx. 5.5 quarts (just over 5 liters) of fluid, so I replaced about 42% of original fill. (2) CVTF LV was used as per specification. Replaced crush washer on drain and flat washer on fill. (3) Shifting "seems" a wee bit smoother, though this may be me wanting an improvement. (4) Removed fluid was nearly identical in color and transparency (light yellow, like honey) to new, and I saw no metal deposits anywhere.
Conclusions: (A) the drain/fill process is straightforward, and is a tad bit more complicated than an oil change. (B) After seeing fluid condition at 10k miles, I'm happy to wait until 30k for next change.
Useful Data: Subaru P/Ns for TR690 CVT
drain plug/gasket: 32013AA080/809326090
overflow plug/gasket: 807016160/803916100
Torques: Drain: 39.2 Nm; Overflow 50 Nm
Hope this helps.
#12 · (Edited)
Not sure how you can be 2 qts off when doing this by the steps listed. Vehicle needs to be running when filling. Use a container that can fit under underneath the vehicle that has graduated markers to properly measure the fluid drained. I found these at Farm and Fleet. Let it sit until the same temperature as the new fluid and mark the level. Dump the old fluid, clean the container and fill to marked level with new fluid per the steps noted on re-fill.
Doesn’t cold oil have less volume than hot oil?
I think you misunderstood. I've seen FA24F based Subies underfilled, because they don't take enough time for the cooling lines and front cooler to fill. People have filled till it starts overflowing, but the cooling lines and cooler havent filled all the way and they end up being short. Some people cap the overflow and run it a few and check again. One guy measured and put a little less in than he took out, and THEN followed the procedure to fill the rest of the way, leaving the plug in until it was nearly at temp.
See attached. Top picture is fill/level check (allen head bolt), and drain is bottom pic (looks exactly like the oil drain plug). You can also look at this video. It is an Ascent, but the same TR690 Xmission as the FA24DIT on the Outback:
Thank you so much! Exactly what I needed.
NO!!!!!!!!
That guy is an Amsoil shill that already destroyed his transmission AND filled it wrong because he has NO idea what he's doing.
He's his my conversation with him, but I went into detail about this, including sharing Amsoil admitting their fluid isn't compatible and parts of my conversation with that shill that he hid on YouTube.
I explain how to do it in my posts over in the ascent forum, or, you can get a 3-day membership to Subaru technical information system and learn how to do it from there. But whatever you do, do not follow his instructions.
Don't use Valvoline either. Stick with Genuine Subaru. WHy? These other solutions are one size fits many, and the Subaru CVT trannies are quite finicky. You will likely have poor performance and perhaps do damage that won't appear for several 1000s of miles. I know it is expensive, but it is still much cheaper than a new trans.
