Have read the various threads re: dipstick drama and difficulty getting a reading that makes sense. However I wonder if my lovely local dealer swapped out my dipstick at the oil change last week.
Any suggestions on getting a proper replacement to prove this -- as all OEM options online seem to say they are not appropriate to my engine model.
Am monitoring suspected head gasket, steering rack and possible oil cool(?) seal issues, so I check the oil religiously. Everyone was booked, so relented and went to dealer last Friday.
It took a few days to get onto a proper level parking spot after the appt. And when I did, this was my dipstick level after 12+ hours parked!
Called, drove down and waited for them to fix this overfill. Was told they had a "problem" with my car. That it calls for 6 QT but that the dipstick was showing over-full at 5.5 QT. Good grief it takes some time for the dipstick to show true reading, it needs to sit a bit. They ask if I've had the oil pan changed or damaged. Or if I'd replaced the dipstick. I mention to them, that if it was replaced, it had happened with them 7 days earlier....
At check out, I overhear the lead tech saying "he'd drained the oil for 5 minutes before refilling, it should be fine but that the customer (me) would know if there was a problem very quickly." When I ask for a new reminder sticker on my windshield, am told I don't need a new one, as they didn't replace the oil filter.
It seems ridiculous –– they've added back in 5.5 QT with an already primed, full of oil filter. And only drained the system for 5 minutes, how does this address the issue of overfilled oil? After making this concern known, all I could do was insist that the service notes indicate they did not replace the filter and the amount of oil added back in.
Today, dipstick still shows wildly overfull, just like the photos from yesterday.
So does anyone have a lead on an OEM dipstick for this engine? Not many H6 in the junkyards. Otherwise I'm going to stalk other H6 owners in the parking lot and ask if I can measure their dipstick and that may have a bad result
