2006 Outback
On the back of the tank there are 2 3/8" hose connections. I believe they go back to the charcoal canister. On my tank the lower hose is disconnected. The nipple coming off the back of the tank rusted off.
I can see the hole with a camera but it is too tight to get a nipple installed there. Can I seal off the hole and creat a new hole in a spot on the side if the tank I can easily access or does that hole have a reason it is where it for some reason?
I can fix this much easier if I can drill a new hole and connect the hose in a different spot.
first photo is the upper line which seems fine. The second is the hole where the lower line broke off.
Thanks!
Thanks!
