The drain plug for the front differential on my 2007 Automatic has started to leak. I’ve got a new OEM drain plug and OEM gasket 803926090. According to the FSM, the torque specs are 32 ft-lb with aluminum gasket and 51 ft-lb with copper gasket. As others I’m sure already know, the OEM gasket is neither, it’s steel.
For others who have already been down this road, have you used the copper gasket specs? Anything else to consider during the drain/fill? I’m also using OEM 75W-90 gear oil.
