Some very interesting information in this thread. Having had the original front & rear diff oils in our Australian spec 2016 3.6R Liberty replaced with Castrol Syntrax Universal Plus 75W-90 I decided to look further into this.
USDM Vehicles:
To me the 2016 USDM Legacy & Outback Owner’s Handbook spells it out reasonably clear for the CVT models.
The below is taken from the USDM Legacy & Outback Owner’s Handbook.
Front Diff:
• Subaru Extra MT (The vehicle is filled at the factory with this type of manual transmission oil/front differential gear oil).
• API classification GL-5 (75W-90) (You may use this type of manual transmission oil/front differential gear oil. However, using this type of oil will detract from driveability and fuel efficiency).
Rear Diff:
• API classification GL-5 (75W-90 recommended).
It is interesting that the 2015 USDM Legacy & Outback FSM is worded differently for the front diff oil in the TR690 (HT) CVT models & the TR580 (Standard) CVT models. For the front diff oil in the TR580 CVT model is just states ‘SUBARU GEAR OIL EXTRA MT or equivalent’, whereas it goes into more detail for the front diff oil in the TR690 CVT models (see ammcinnis' previously posted links).
Australian spec Vehicles:
The Liberty & Outback Owner’s Handbook that came with our Australian spec 2016 3.6R Liberty indicates the following for the front & rear diff oils in the CVT models (no mention on that table about manual transmission). Note that it doesn’t give the preference or warnings that the USDM Legacy & Outback owner’s handbook gives.
Front Diff:
• Subaru Extra MT (Equivalent to factory-filled oil).
Rear Diff:
On the previous page to this it covers the manual transmission oil (obviously for the diesel manual) with no mention about the front & rear diff oils.
This indicates for the manual transmission oil (Note the preference & warning for the manual transmission oil).
Manual Transmission:
• API classification GL-5 (75W-90). (You may use this type of manual transmission oil. However, using this type of oil will detract from driveability and fuel efficiency).
Subaru Australia on their website recommends Castrol Professional oils for the engine (they don’t mention recommended brands for front or rear diff oils though).
On the Castrol Australia website, both the front & rear diff oils recommended for the 2015-2017 Liberty 3.6R CVT model are: CASTROL UNIVERSAL 80W-90 or CASTROL SYNTRAX UNIVERSAL PLUS 75W-90. This is on the
Castrol retail oil selector guide & also on the
Castrol trade oil selector guide.
After this I feel confident using Castrol Syntrax Universal Plus 75W-90 in both the front & rear diffs of our Liberty.
I'm not sure why the information for USDM Outbacks & Legacys is different (unfortunately I don't have an Australian spec FSM for further comparison). Perhaps the Subaru Extra MT oil being 75W-80 is more suitable for a colder climate, or perhaps it gets rid of the heat quicker – just a guess.
