Haldex systems, with a few exceptions, are primarily FWD-biased. In fact, the Gen1 Haldex transmission only engaged the rear wheels after the front wheels had already slipped. Newer systems have full time 4wd, but are still biased to 95% FWD, with the ability to distribute varying torque bias depending on the car it's in.
Does this make it bad? Not at all. Variations of Haldex units are used in everything from the Bugatti Veyron to Volvos, although I will say only the Audi A3 variants currently use Haldex units. Most Audis use Torsen components now.
By contrast, Subaru's "symmetrical AWD" is designed from scratch to deliver standard 50F/50R torque distribution. Most models use a simple viscous coupling center differential to achieve this. While extremely primitive by modern standards, it is very reliable at factory power levels, and is astonishingly effective at maintaining traction.
The 4 and 5eat, as well as the STI's DCCD system replace the viscous center coupling with an electronically controlled clutch pack, which offers active torque bias control (and DCCD offering direct user control).
Older generation Subarus used limited slip rear differentials, but most (if not all) of the current models have abandoned the LSD in favor of computer controlled wheel braking, which simulates the same effect. Coming from the WRX world, this system seems to be just as effective as the LSDs, and means cheaper repairs down the road (just replace brake pads).
While simple, reliable, and effective, the glaring drawback to the symmetric system is vehicle weight distribution. By physical necessity of the configuration, the engine and much of the transmission is located entirely forward of the front axle, lending to a heavy front bias on all Subarus (BRZ excluded). I'm not sure how many people on here AutoX, but in the WRX world, this leads to catastrophic understeer. Subaru will say the lightweight and compact boxer engine improves this problem, which is true to a certain extent, but weight balance will continue to be a factor for as long as Subaru maintains this configuration (i.e. forever).
