I said I was ranting!
But please ask Subaru or any manufacturer and their engineers the following question: "Please be specific of your definition of "Lifetime"?" Is 70,000, 100,000, 200,000, 1,000,000 miles? Is it when the warranty ends? What? They won't give you a specific number. Period.
Yes, the longevity of coolant has been increasing over the years. I remember when we just used water. Then the green came out, and guess what... It was sold as "Lifetime" coolant. We learned that wasn't true, we ended up having to change it out every year or two. Better chemistry, engineering has increased it's life to be longer and longer. Yes, there are some go a really long time. But it still need to be changed at some point.
Fluids are the life blood of an engine. Oils, coolant, etc. They are necessary to keep an engine working. Fluids don't last forever. When the fluids break down, the engine breaks down. Every tear open an engine that never had an oil change? It ain't pretty, trust me, I've seen it. Same holds true with coolant passages when the coolant has never been changed.
When machining parts, they are machined to a specified tolerance of a + or - dimension. Fluids are designed similarly, with Best Case (longer duration between change), and Worst Case (shorter duration between changes).
As for this situation, it's basically stated as Best Case: 11years/137,500 miles. Worst Case: 6 years/ 75,000 miles (also it's which ever comes first, the year or the mileage). With the SAME coolant. It's always better to error on the worst case side of things just to be safe. You can ask an engineer that's been around awhile, and they will say the same thing. Better safe than sorry.
Hence, when I see manual that has two different numbers for the change interval (one for "normal" driving, one for "heavy" driving) I personally just go for the "heavy" driving interval. Again, better safe than sorry. You may not agree.
Besides coolant is what $20 a gallon? Need 2, maybe 3 gallons? 40 or 60 bucks? Compared to what you paid for the car? To help it last longer, yeah, I'm going change it at the worst case scenario. I LIKE keeping my stuff for a long time (especially mechanical stuff, it's my thing. I guess growing up with a parent that was mechanical engineer helped).
Now if you really want to get picky... The date/mileage change interval is total BS. What you really want is a run time interval. i.e Change oil after 200 hours of run time. Change coolant after 1000 hours of run time, type of thing. We only use date/mileage is because it's convenient. There were cars in the past that actually had a run time clock and the manuals stated fluid changes in bracketed of hard or easy driving hours of run time. There weren't many, but they did exist.
Ok, my rant is over. I got it out of my system. I usually have a 5 year span between this topic/rant. I was past due. Sorry.
