21 - 30 of 30 Posts
Our 24 has the big light on the mirror housing. It seems I often don't notice it when it activates, it's almost like I look right past it. It's in a weird spot that like some have said requires a refocus away from the mirror I'm actually looking at. I suppose I see it in my peripheral vision but it hardly stands out or works well for me in this location on the drivers side. For some reason it's more noticeable on the passenger side. Must be the distance between the light and myself, and wider focal vison/path of my eyes.
Have you had an eye doctor check your peripheral vision ? At almost 70y/o and been wearing glasses since my early 40's mine is tested yearly.
I know, it's no substitute for an audible warning though. Like I said, for as many beeps as these cars make, it's mind boggling they didn't include that as one of them.
I'll play devil's advocate, and say that the vehicle makes too many beeps already, I don't want/need yet another one. In heavy traffic, I typically signal my lane change shortly after the car in the adjacent lane is far enough ahead that the other driver doesn't see it, but the driver behind them does see it (hoping in vain that they'll leave the spot open...). The blind spot indicator is almost always still on for the passing vehicle, I don't want/need a beep every time I do this.
Making the beep an option would be fine though.
Yeah, too bad they didn't make the car beep if you hit the turn signal with the BSD active. The car beeps for every other damn reason other than that.
My 2020 Outback limited will sound a rapid series of beeps if I turn on the turn signal while the Blind Spot Indicator is active.
That's interesting. My 2020 Outback Limited only beeps with rapid flashing when moving in reverse. When going forward I only get rapid Flashing with Blind Spot Detection when the turn signal is on, no beeping.
So I looked in the manual, and it only mentions rapid flashing while moving forward, and rapid flashing and beeps when in reverse. Are you sure you get beeps when moving forward?
that was one of the main reason I bought my 24 OBL& the rear cross traffic alarm has helped @ least 2 x and the BSD has helped making merging onto the fwy's or changing lanes safer
21 - 30 of 30 Posts
